Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2JZ-GTE VVTI swap thread.
Old 05-06-2012, 10:05 AM
  #61
bbs350z
bbs350z's Avatar
Originally Posted by midz350
That guy from Russia used the stock ones, so either that or build new ones.
I will install the R154 for now, but will sell it later and install the 350z tranny.
This project may go crazy big. Found a rebuilt short block for cheap among other things.
what are the gears of the cd009 in comparison to the 6 speed supra trans? also, what rear end are you gonna be using, 3.5, 3.33, custom gear??
Old 05-06-2012, 10:18 AM
  #62
high boost
high boost's Avatar
your gonna wanna fab new motor mounts also u do u have the right bell housing for the r154 cause its not gonna mate up otherwise also why did u get ecu if your gonna run a standalone
Old 05-07-2012, 04:19 AM
  #63
midz350
midz350's Avatar
I will be using the 3.5 with the R154 and might go 3.3 if I swap the 6MT.
Old 05-07-2012, 04:24 AM
  #64
midz350
midz350's Avatar
We will see.
Yes, I have the right bell housing for the r154-2jz.
I got the ECU to test start the engine.
Will pick up the OS Giken triple today.
Old 05-10-2012, 07:48 PM
  #65
midz350
midz350's Avatar
I picked up the head with the HKS 280 cams, OS Giken triple clutch and AEM cam gears.
the clutch is missing the pull to push alteration kit. I might convert it just like the W58 tranny or buy the OS Giken kit for around $500.
Attached Thumbnails My 2JZ-GTE VVTI swap thread.-20120511_062758-1.jpg   My 2JZ-GTE VVTI swap thread.-20120511_062832-1.jpg   My 2JZ-GTE VVTI swap thread.-20120511_062849-1.jpg   My 2JZ-GTE VVTI swap thread.-20120511_062920-1.jpg
Old 05-10-2012, 07:52 PM
  #66
Flo-ridaZ33
Flo-ridaZ33's Avatar
What would you convert to a W58?
Check out Travis' 2J build... you might find some good info here:
https://my350z.com/forum/engine-and-...-re-build.html
Old 10-06-2012, 12:32 AM
  #67
midz350
midz350's Avatar
Update:
Due to a financial problem I had to sell all of the above and I was thinking about getting a stock VQ35HR, but now I bought another stock 2JZ-gte and later today will order the 2JZGTE engine to 350Z 6-speed tranmission adaptor kit which includes:
The 2JZ/1JZ Engine to 350Z/370Z Transmission adapter plate,
Light weight Aluminum Flywheel MADE TO FIT THIS SWAP
Six Puck sprung hub clutch disc FOR THIS SWAP
Stage Three pressure plate MADE TO FIT THIS SWAP
Pilot bearing adapter
The bolts to fasten the adapter plate to the engine
click me
Old 10-06-2012, 04:10 AM
  #68
graffkid732
graffkid732's Avatar
Update:
click me
Nice nice. Good luck with that. I was in contact with one of those guys awhile ago. Looks like the same guy, not 100% sure. Any plans for modding? I thought the stock twins won't fit? I could be wrong.
Old 10-06-2012, 04:28 AM
  #69
midz350
midz350's Avatar
They fit but you have to do some (forged performance massaging) to the firewall.
Old 10-10-2012, 10:47 AM
  #70
Highway Riding
Highway Riding's Avatar
Try to get a cast single manifold and Precision 6266. No more than $1100 new and you'll be moving....
Old 11-09-2012, 12:45 PM
  #71
hinds90
hinds90's Avatar
Has anybody actually used that adapter kit yet?
Old 11-09-2012, 07:12 PM
  #72
midz350
midz350's Avatar
Yes they did in MyIS IIRC. I'm not using that kit any more (they stopped returning my emails) I'm going with a V160 flywheel and 350z clutch kit (its the same size clutch plate)
and making my own plate.
I already have an exhaust manifold and will go 6266 or even 6766.
I'm still looking for a way to make the stock tachometer works.
Old 11-09-2012, 10:04 PM
  #73
hinds90
hinds90's Avatar
Hmmm I'm highly interested in doing the 2jz swap and would rather keep the 6spd. It says he has a quantity of 5 kits on eBay. I've come upon a 350z for dirt cheap and don't want to deal with the hassle of blowing the stock or built vq so would just rather go with a 2jz for reliable 450whp.
What mounts can be used. Lol I know I sound like a 16 year old with pipe dreams but when I get back stateside you will see a build thread.
Old 11-09-2012, 10:46 PM
  #74
midz350
midz350's Avatar
I just got the engine to the shop and I need to get all the parts to start test fitting the engine. Will keep this thread updated once we start.
XAT racing did an adaptor to get the stock tachometer to work 2-3 years ago with a Haltech.
Old 11-24-2012, 11:51 AM
  #75
midz350
midz350's Avatar
I found a Greddy T88H 38GK turbo that I'm consedering and 1000cc Sard injectors, Sard regulayor and HKS fuel rail. All that for ~$1900.
Also contacted Abbey motorsport in UK about the Syvecs S6 and they said I can use it to run the 2jz and make the stock tachometer work and have a traction control via the 350z CAN BUS.
Old 11-28-2012, 04:53 AM
  #76
Highway Riding
GL man keep at it!
Old 12-09-2012, 04:18 PM
  #77
Resmarted
Resmarted's Avatar
Bump.
So what exactly are you planning on doing for the motor mounts?
Old 12-09-2012, 04:22 PM
  #78
graffkid732
In for some new updates as well. I can send ya pics of my mounts if you would like and take some dimensions to give you a round about idea.
Old 12-09-2012, 06:28 PM
  #79
Resmarted
Resmarted's Avatar
That'd be cool. I'm considering gathering up a few 2j parts for a swap in case of a popped vq.
Old 12-10-2012, 12:15 AM
  #80
midz350
midz350's Avatar
We need to get all the parts to bolt the transmission to the engine and get the turbo and exhaust manifold before we start working on the mounts.
Graffkid, thank you but I'm using the 350z transmission, so I think it won't be the same.
I'm just waiting foe some cash to get all the needed parts.
Also, someone local did couple of 2jzgte swaps in the 350z and he said he can get the stock tachometer to work and it cost less than $50!! He said something about the Z tacho uses a higher voltage than the 2jz output!!
Quick Reply: My 2JZ-GTE VVTI swap thread.
