JWT cams on revup question
I have a 2006 revup and I am thinking about doing JWT s7 cams. Will the cams still make power if I don't add headers? I don't ever plan on adding headers. I live in California and don't want to deal with header and smog issues.
Here are my mods ...
* motordyne mrev2
* motordyne plenum spacer
* ams pullies
* nismo exhaust
* motordyne XYZ y pipe.
Now before you tell me it's not worth the money ... I have a oil leak. The leak is coming from the rear timing chain cover. I am fixing the oil leak and basically it will not cost me any extra labor to add the cams since repairing the oil leak will basically have it all apart. Yeah the cams and springs are not cheap but if it's all apart ... And I can add some power ... Now is the time to do it!
* motordyne mrev2
* ams pullies
* nismo exhaust
You will have some gains, just not the full gains without the full supporting mods
I am running stock cats and don't plan on ever changing the cats. Also running stock headers and don't ever plan on changing those. I am in California and don't want to change back and forth.
I am pulling it all apart to fix the oil leak so I will be there .... Adding the cams will only cost me cam cost and springs. $1000 so 10hp gain .. 100 per hp lol
Yeah ... Already getting a Dyno tune since I have added motordyne mrev2, motordyne spacer, motordyne XYZ y pipe, nismo s tune mid pipe, nismo s tune muffler and a JWT Pop charger in the past 60 days. I get most won't do cams ... I guess my real question is will I get 10 or more rear wheel HP A GAINS with the JWT s7 cams and my setup?
