Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Engine, Drivetrain & Forced-Induction (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 02-19-2009, 05:59 PM   #1
Mr.Jadkowski
Mr.Jadkowski's Avatar
Points: 2,690, Level: 31
Points: 2,690, Level: 31 Points: 2,690, Level: 31 Points: 2,690, Level: 31
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Send a message via AIM to Mr.Jadkowski
Default Z1 Plenum Spacer Install How-to
This is really not a technical job at all, but I realize working on your own car can be intimidating if you've never done it before. So I took some photos and notes as I installed my Z1 plenum spacer yesterday. I'm not going to completely duplicate the install instructions from Z1 Motorsports, but they can be found here, and a printed copy is included with the plenum spacer. Lets get started!
Difficulty: 1-2 beers
Time: 1 hour or less
These are the parts included with the kit. You can find the breakdown in the instructions, but I was pleased to see that they included some extra hardware, which comes in handy when you inevitably lose a bolt or washer (even with my magnetic parts bowl, which I highly recommend).
These are the tools that you will require (They are also listed in the instructions). 10mm socket for the bolts on the plenum, a 14mm socket for the strut bar bolts, a ratchet that will drive both those sockets, and an extension that fits the 14mm socket to get to the strut bar nut. I also used my 1/4" drive nut driver (screwdriver looking thing) to speed up removing the 10mm bolts, and also to install them without over-torquing them.
Step 1: Remove the bolts and nuts for your strut tower. I found mine to be really tight, and had to use a breaker bar to break the torque on them. However, I've taken the bar off before and I probably torqued them on too tight the last time. You'll probably have to use your extension to get to the two nuts on the strut bar, and the bolt that comes up out of the strut mount can make it hard to seat the socket all the way down with an extension in it. I put the socket on the nut, then pushed the extension into the socket. It didn't go in fully, but I'd rather round off my extension than that nut!
Now remove your strut bar. You'll have wiring clipped to the bar that can be a ***** to remove (mine was) so I ended up just swinging the bar out of they way as needed, and that provided plenty of clearance.
Step 2: Remove the nuts and bolts that hold the engine cover down, and remove the engine cover. It's pretty self-explanatory, there are two bolts and two nuts (if I remember correctly). The only tricky part is that there are brass bushings inside the holes used to mount the engine cover, and these can fall out if you're not careful. This is what's underneath that cover, if you've never seen it before.
Step 3: Remove all the bolts from the plenum and carefully lift it upwards. You'll need to keep some of the OEM hardware (the four bolts on the back edge of the plenum, and the three rear bolts on top of the plenum, but reference the instructions to be sure you're using the right ones), so seperate those bolts from the rest, but don't discard anything until you're done! I also had to remove a bracket holding something (not sure what) to the back of the upper plenum so I had more wiggle room to lift it, but that's just preference. Check out your OEM gasket and make sure it's still properly aligned. Also, be careful while you have the plenum open; anything that may find its way in there will most likely be sucked into the engine the next time you start it!
Step 4: Place the plenum spacer in on top of the OEM gasket. If you don't have someone else there to hold the upper plenum for you, it can be a bit of a pain to get it in there. Be sure not to disturb that OEM gasket, and once you do have it in, double check to make sure everything is aligned. For reference, the thicker part of the spacer faces the front, but there is only one possible way you can put it in so don't sweat it.
Step 5: Place the new gasket (included with the spacer) on top of the spacer, and align it. This would probably be easiest to do BEFORE you put the spacer in, but it's still not that difficult to get that thing in there on top of the spacer by yourself. I didn't take a picture because it's pretty self-evident what you need to do. Just be sure that all the bolt holes in the gasket are lined up with the spacer, and the bolt holes in the spacer are lined up with the holes in the lower plenum. Once you have everything square, carefully lower the upper plenum onto the new gasket and spacer.
Step 6: Start threading bolts back through the upper plenum, spacer, and into the lower plenum. I started with the bolts in the back (these four are re-used). Hand start the bolts just enough to get them threaded. Leave them plenty loose in case you need to move the plenum or spacer around to get everything aligned. In this picture you can also see the bracket I removed from the upper plenum. I remounted the bracket once I had the plenum fully bolted down.
Next I hand-started the bolts on top of the plenum. The three rear bolts are new hardware supplied with the spacer. The three front bolts are re-used OEM hardware. HOWEVER, those three bolts were originally in the REAR holes. Be sure you're using the correct OEM hardware! You can tell which bolts are new and which are old in the picture. All six bolts have a rubberized washer underneath (also supplied with the spacer).
Last, use six of the smaller bolts supplied with the kit (as well as a small metal washer for each bolt) and hand start the bolts in the rest of the mounting holes (Four in the front, one on each side). Two studs coming out of the lower plenum, which originally had nuts on them, are no longer used and will be left without hardware on them.
Once you have hand-started all the bolts, and are sure everything is lined up, torque all the plenum bolts to 44-61 INCH-POUNDS. Yes, inch-pounds, not foot pounds, so don't break out your monster torque wrench. I don't have a torque wrench that goes that low, so I used my nut driver and guestimated the torque. A rule of thumb, so I've been told, is that the tightest you can get a bolt with a nut driver and bare hands is 100 in-lbs. So tighten it about half as hard as you can go, and that should be within range. I would worry more about over-torquing them than under-torqing, keep in mind that if you're using a 6" ratchet it will only require 10 lbs of force on the end of that thing to over-torque the bolt.
Step 7: Replace the engine cover using the OEM nuts and bolts. It's not going to fit quite right because the plenum will now sit higher, but it'll still go on ok.
Step 8: Reinstall your strut bar. Since the plenum is raised, you're probably going to require additional clearance. There are some large washers provided with the spacer for this. This will vary from engine to engine, but I used two washers under each inside mounting point, and one washer under each outside mounting point (there were 12 washers supplied, hence the odd number). Be careful not to drop those washers down into your engine bay, as they'll end up on that lower engine cover and if you don't have skinny bird arms (luckily I do!) you'll have a really hard time getting them out. Once I torqued the strut bar down, I also used the adjustment bolt to lengthen the bar for a little additional clearance. Keep in mind that when your engine is under load it actually twists in the engine bay, so what may look like adequate clearance with the engine off (or idling) may cause the plenum to contact the strut bar while driving. This will cause a vibration in the car that you can hear and feel. In that case, take your bar back off and add another washer underneath. My bar has about 1/4" clearance minimum with the engine off and that's adequate to keep it from touching.
Once you're sure the strut bar is secure and has adequate clearance, you're done! Go wash your hands and take it for a drive! In my car, the most notable increase is in the low to mid power band, and was enough to make a $160 part seem worthwhile. This was part of my ongoing BSP autocross build, so we'll see what kind of difference it makes at the next event. And besides that, you drank a beer and got your hands dirty working on your car, that's always worthwhile!
Mr.Jadkowski is offline   Reply With Quote
Old 02-19-2009, 06:35 PM   #2
oddjobbb
oddjobbb's Avatar
Points: 2,008, Level: 27
Points: 2,008, Level: 27 Points: 2,008, Level: 27 Points: 2,008, Level: 27
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Thanks for the DIY. just got my Z1 plenum spacer so this will help when i install it this weekend.
oddjobbb is offline   Reply With Quote
Old 02-20-2009, 06:20 AM   #3
bryan@Z1
Vendor - Former Vendor
bryan@Z1's Avatar
Points: 7,997, Level: 60
Points: 7,997, Level: 60 Points: 7,997, Level: 60 Points: 7,997, Level: 60
Send a message via AIM to bryan@Z1
Thanks for the write up. Nice job!
bryan@Z1 is offline   Reply With Quote
Old 04-09-2009, 09:26 AM   #4
johndoesdamage
Points: 1,633, Level: 23
Points: 1,633, Level: 23 Points: 1,633, Level: 23 Points: 1,633, Level: 23
Today's Activity: 2.5%
Today's Activity: 2.5% Today's Activity: 2.5% Today's Activity: 2.5%
I installed my md 5/16 spacer yesterday and I dont know how to adjust the strut bar.My car shakes a little when Im at idle or 1st gear to like 3000 rpm. Would it be better I take it off until I find out how to adjust it? Its on right now but not like fully bolted on so prettty much use less I think.
johndoesdamage is offline   Reply With Quote
Old 06-26-2009, 02:55 PM   #5
mattman87
Points: 3,813, Level: 39
Points: 3,813, Level: 39 Points: 3,813, Level: 39 Points: 3,813, Level: 39
I would, it fine to drive without the strut bar. I also might add that you should be careful that you do not have too much clearance, you might go drop your hood and hear a nice whack - like leaving a wrench in the engine bay haha.
mattman87 is offline   Reply With Quote
Old 06-28-2009, 11:16 PM   #6
hoypinoyboy
hoypinoyboy's Avatar
will it make a difference if i didn't use the bolts that came with the spacer? i bought a motordyne 5/16 spacer but my mechanic decided to use the original bolts? will this affect anything?
hoypinoyboy is offline   Reply With Quote
Old 06-30-2009, 06:30 AM   #7
2004Black350z
Exhaust Whore
2004Black350z's Avatar
Points: 4,351, Level: 42
Points: 4,351, Level: 42 Points: 4,351, Level: 42 Points: 4,351, Level: 42
Today's Activity: 29.9%
Today's Activity: 29.9% Today's Activity: 29.9% Today's Activity: 29.9%
Quote:
its gonna blow up.
OP nice write up. Whats ur review on the spacer?
__________________
Tuned by CIN Motorsports
2004Black350z is online now   Reply With Quote
Old 06-30-2009, 08:59 PM   #8
hoypinoyboy
Quote:
Originally Posted by 2004Black350z View Post
its gonna blow up.
haha funny... i was just checking because the stupid stock bolts loosened up but i replaced them...its not running shitty so i know its koo ... but i forgot to mention the torquing recommendation ...i didn't torque it to the certain pounds thats what i really wanted to know
My350Z
350 Z
Paid Advertisement
Tags
24, 350z, bar, bilts, bolt, breaker, diy, driver, inch, install, motorsports, plenum, remove, spacer, strut, z1
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
