Engine Swaps For all your engine swap experiences, ideas, questions, & more..
Engine swap: learn to burn
Old 01-15-2016, 06:29 AM
iideadeyeii
iideadeyeii's Avatar
10k
http://www.importpartspro.com/st1vqloblni3.html
Long block 5k plus sending core back +500 5.5k
Used full turbo or supercharger setup with tune 4.5k
400whp /end thread
The following 2 users liked this post by iideadeyeii:
DEVRma (01-15-2016), Syner (01-15-2016)
Old 01-15-2016, 06:36 AM
DEVRma
DEVRma's Avatar
Originally Posted by Syner
What's your budget?
Someone did a 2JZ build on here recently; he ended up sinking a ton of money into it doing things right, only to part it out (I'm guessing to recuperate some of his money)
About 10k. Its either between a 1JZ or RB now. Me and my friend who plan on working on it have settled on either or. Of course we have all the equipment/tools.
Old 01-15-2016, 06:39 AM
Syner
Syner's Avatar
Read this: https://my350z.com/forum/engine-swap...jz-350z-4.html
Yes, he had some shop help, but read post 68 specifically: https://my350z.com/forum/engine-swap...l#post10645694
A lot of surprise costs can pop up.
DEVRma (01-15-2016)
Highway Riding
Highway Riding's Avatar
10K would do a JZ swap with the OEM\JDM twins which blow donkey d but can work just fine if the seals are not blown. A 1JZ is super cheap but most likely will have a jacked turbo if not a later VVTI model which will cost more. Then you will need collins adapter and associated bits, wire harness, exhaust fabbed, wastegate, bov, intercooler, rad hoses then most likely the most expensive piece a ECU. Driving on a JDM ecu works but 1JZ ecu's are know to have blown resistors and just a PITA..
DEVRma (01-15-2016)
Old 01-15-2016, 06:53 AM
DEVRma
DEVRma's Avatar
Originally Posted by iideadeyeii
10k
400whp /end thread
That honestly beats all. That's badass, plus a "drop in and tighten" level of work.
Old 01-15-2016, 07:03 AM
DEVRma
DEVRma's Avatar
Haha, yeah, sticking with the vq. Thanks everyone, ill still look into an RB before anything though.
Old 01-15-2016, 07:07 AM
iideadeyeii
I win!!!
Old 01-15-2016, 09:05 AM
Highway Riding
I would say RB is a no go at all. Too expensive with regards to parts and maintenance. You will easily see this when sourcing parts.. Especially JDM twins.. Eff that
DEVRma (01-15-2016)
Old 01-15-2016, 09:37 AM
armt350z
armt350z's Avatar
RB is a pipe dream for you most likely. This is whats on my workbench right now...
Its a 600whp build and its already past your budget.
DEVRma (01-15-2016)
Old 01-15-2016, 10:10 AM
DEVRma
DEVRma's Avatar
Ol
Yeah i just got done doing research on such. That is out of reach due to circumstance :'(.
But armt,thats awesome! i cant wait to see the finished build.
Old 06-25-2016, 12:29 PM
Dirty ol Dog
Dirty ol Dog's Avatar
Hi DEVRma
I like the fact you are willing to learn as you go, and you sound like you are a very determined person. Good for you Mister!!
As for your plan to swap in a non native engine, I know from many years of building ridged framed road slugs using all kinds of 60's or even 70's era Trump or Norton frames or modding something else. You learn fast! My engine swap experience is mainly in the area of Chev to Chev or Ford to Ford although I've done some Frankenstein's in my day.
I don't know if it's been suggested amongst all the forum Gods comments or not, but for an initial project like this one have you thought of buying a donor car like a g37, or 370z and starting there? Lots of opportunity to mod up a 350z with a more modern engine trans package that has 50 or 60 and is still in the family so to speak the vq3.7. It can easily get for very cash get 50 or more hp out of small NOS kits and or Methanol kits. You can double the stock hp of the 3.7 with air induction like blowers or turbos.
there are new and used things out there. Plus there is little fear of blowing it up or busting the crank these adders are built to safely produce double the stock hp and more with the right tune.
This is just a view from the cheap seats, I hope that what ever you decide you'll get some visuals on it and keep us updated
Cheers
Dirty
Old 06-27-2016, 05:02 AM
Syner
Syner's Avatar
Originally Posted by Dirty ol Dog
Hi DEVRma
Cheers
Dirty
Help, I think I've had an aneurysm.
Old 09-10-2016, 05:57 AM
Bader_2360
Bader_2360's Avatar
There is nothing hard in swapping the 2JZ in the 350z. just plan your swap properly and find an experienced mechanic who is familiar with the Supra/350z (if you can't do it yourself) and organize your priorities. first get the parts that you need to get the engine running and drive your car. then. think/plan for the 600-700hp build after that.
My 2JZ swap took exactly 7 months which was slow IMO since my mechanic was a very slow guy and he had to move his shop to another place during the swap.
first. I got the engine/trans, mounts, clutch, harness, intercooler/piping, fuel pump, drive shaft, as well as some 2jz maintenance parts like new timing belt, water/oil pumo and thats it, we started the swap.
now that car is running with the 2jz trouble free. I just did a 4 inch custom exhaust last week (remember good planning for the 600-700hp build) which turned out nicely. the only issue I have now is a minor battery parasitic drain issue which is not hard to fix. the other issue resulting from the swap is that the car is pretty heavy at the front now because of the much heavier 2JZ engine & i'm looking for a suspension that will solve this issue & that shouldn't be hard as well.
Old 09-10-2016, 06:14 AM
MartinZ
MartinZ's Avatar
The handling and steering turn in response of the 350Z is one of the big plus factors for the 350z
I would be devastated if the handling was inferior after the engine swap
Don't want to change the front/rear weight distribution
Don't want more weight ahead of the front axle line
(Suspension changes may help mask the problem but won't bring it back to stock handling)
Old 09-10-2016, 06:30 AM
Bader_2360
Bader_2360's Avatar
well of course a 2JZ swap should never be meant for handling/agility. its only for drag and straight accelerations. otherwise, the swap is done for the wrong purpose.
MartinZ (09-10-2016)
Captain_Chris
01-23-2016 08:50 PM
silvertouringz
01-20-2016 05:53 AM
openupitsdave
01-18-2016 05:58 PM
JonGon
01-14-2016 09:05 AM
Quick Reply: Engine swap: learn to burn
