First time vinyl wrap...
Old May 24, 2012 | 09:18 PM
  #61
Qtip350z's Avatar
Qtip350z
Just like the last post, Plus keep a straight line as much as possible all the way down and try not to over stretch the vinyl again and again, It will make it a lot harder to flatten out the vinyl all the way down the panel.
It is a lot easier to vinyl the panels on the car, Your photo looks like its indoors.
Sometimes it easier to just start all over, I did many times!
Good luck!
Old May 24, 2012 | 10:00 PM
  #62
schift's Avatar
schift
Wow, this is the first flat black Z I've actually liked the look of. Good work.
What do the door jambs look like? Did you wrap them also? (as well as the underhood/hatch)
Old May 25, 2012 | 01:29 PM
  #63
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Wow that wrapped Bimmer looks killer.
Old May 25, 2012 | 06:18 PM
  #64
Phil Klepka's Avatar
Phil Klepka
How did you do the antenna? I messed mine up, but... I have a solution involving white carbon fiber. Don't have the vinyl to redo it so this solution will have to work - put a circle around the antenna of white carbon fiber vinyl. It'll match somewhat, but won't be such an obvious mess up.
<a href="http://s232.photobucket.com/albums/ee267/Karkiss/?action=view&amp;current=cf9f4e42a69e11e19894123138140d8c_7. jpg" target="_blank"><img src="http://i232.photobucket.com/albums/ee267/Karkiss/cf9f4e42a69e11e19894123138140d8c_7.jpg" border="0" alt="Photobucket"></a>
No close up of the antenna, but this is how it came out. Yea, it shows the dents -_-
Old May 25, 2012 | 10:15 PM
  #65
Qtip350z's Avatar
Qtip350z
I did not wrap the door jambs.
I just made a nice straight cut down the door line. It looks good!
Same for the hatch area, nice straight cuts turn out well!
I removed the antenna and base first, Then vinyl the rear quarter panel!
Old May 26, 2012 | 10:39 AM
  #66
Phil Klepka
Sorry for asking a lot of questions, just want to double check everything. What did you do with the edges in the wheel well? Did you just wrap them around the fender lip? Also, how did you deal with the door jamb edges. I'm assuming matte black fits better on a black car, but I just took the edges and left them in the door jamb. Obviously there when you open the door but whatever.
Old Aug 27, 2012 | 11:49 PM
  #67
sambo's Avatar
sambo
do you need to use water when you peel the vinyl? like doing window tint.
can you use a hair dryer instead of the heatgun?
Old Aug 29, 2012 | 05:15 AM
  #68
eZg's Avatar
eZg
No water used on most newer vinyls
Yes you can use a blow dryer but harbour freight has $15 heat guns
Old Aug 29, 2012 | 09:11 PM
  #69
Blue Batmobile's Avatar
Blue Batmobile
Inventor
Blue Batmobile
nice.
B@t™
Old Aug 30, 2012 | 12:55 AM
  #70
Aieeeya's Avatar
Aieeeya
Nice to see some locals here. Great work on the wrap and a tastefully modded Z. Maybe do a cruise up to Squamish before the weather gets crappy. =)
Old Aug 30, 2012 | 06:01 AM
  #71
Nissanius's Avatar
Nissanius
Very good job!
Old Aug 31, 2012 | 09:38 AM
  #72
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
In for info.
Old Aug 31, 2012 | 10:11 AM
  #73
A-Town-Z's Avatar
A-Town-Z
Pretty sick wraps in here. In for moar pics!
Old Aug 31, 2012 | 12:41 PM
  #74
STL 350Z's Avatar
STL 350Z
I'd love to do this but I know I'd frak it up.
Obadabot
Jun 18, 2023 11:31 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
