'06 headlights use '05 HID harness?
So I'm finally doing the full conversion of my HID '04 (I did the conversion from '04 base model to '05 HID) now to 06 Bi-Xenon. Woohooo....sort of...
If I buy 06 housings without the harness....can I use my 04 harness that I converted? Well...really my harness is an '05 HID harness that I converted..but you get the idea if you're familiar with the whole headlight hacknology.
I was just reading that the high beams on the 06 is a solenoid activated lever whereas the 05 HID's high beams are a separate bulb of course....so....does the connection in the harness of the 05 HID harness just mate up to the 06 housing, or do I have to buy an 06 harness and then convert that?
So hoping there's an easy answer to this...all help appreciated,
Saved
P.S. - Anybody know of a deal on D2S bulbs by the way? I know I need to get a good one, Phillips, Osram, etc...but taking the long shot while I'm typing to ask if anyone has a deal source or has an extra pair they want to sell?
Saved
General & Tech Moderator
I doubt it.
You can call Courtesy Nissan in TX, 972.231.2600 and ask. They are quite helpful.
Or
courtesyparts.com, search under wiring. gl
Or
Master
Saved
Saved
jhc (07-25-2015)
SR71 (07-16-2015)
I recently did the conversion from my 04 HID to the 06 (My 2004 is the Enthusiast Roadster). the 06 lights came with only the HID bulb & no harness.
These were the problems I had while using the 04 harness:
Lost High beams due to the 06 being a bi-xenon high beam, the 04 harness was not plug in play for the high beam connection.
Blinker socket was too small on the 04 harness, the 06 seems to be a larger size and you will need some tape to hold the blinker in properly w/out falling out.
The DRL bulb (upper one) found in the 04 will have no place in the 06.
If you're okay with soldering / connecting / cutting the wires to work for your High beams and DRL then its no biggie, which I did, but that blinker being to small still irks me today.
It would have been so much easier to find the harness but I wasn't able to so 04 it was! I hope you have an easier experience than I did
You should not lose high beams if wired up correctly or have funky blinkers. You can make a jumper harness out of a power supply cable from a computer to avoid soldering. Take off the harness cover on opposite ends to plug the pins into the car and headlight side harness. I did my conversion back in 2006 and everything functions as should.
Thanks you guys for the awesome added info.
And GREAT tip on the computer power cord adaptor , I have some in a closet or drawer or somewhere..I'll find em...and try to make use of the, the wiring and soldering doesn't put me off as long as I get the correct wiring pattern to follow...the first time I did it not all the wires looked the same on each end of the adaptors...the six pin adaptor wires and the same ones in the eight pin adaptor were not all matching....but I got through it.
I'll post back once I'm up and running and share any helpful tips, thanks again sincerely!
Saved
Saved
Sorry if I'm being dense , just not happening as smoothly for me over here for some reason. IQ could be that reason.
Saved
Props on the computer plug idea, however the lights I received from a coworker had larger blinker socket holes which has nothing to do with wiring correctly. Its possible I got a form of aftermarket 06 headlights made to look like OEM, but everything looks right to me. It seems that everyone has a different story on the conversions lol. The only real re-wiring that i had to do when putting an 04 harness into an 06 headlight was wiring in the +/- of the high beams (green/black) & the DRL (mine were painted over so I chose not to) of course, everything else including the actual "Headlight-to-car" plug was just fine
People just don't always read thoroughly when these questions pop up. The more common questions is "how do i connect my new 8 pin headlights to my 03-05 6pin car". This problem just requires a swapping connectors and making the appropriate connections since the new headlights have the correct harness. This is what MrSparco's solution is actually for.
What the OP and you are talking about (using an 03-05 harness in an 06-08 housing) is a completely different problem.
As you've mentioned the blinkers are a different bulb/socket size (the socket is part of the harness). You can source the correct sockets and replace the ones on your harness to correct that.
Also the 06-08 use a solenoid to activate hi beams rather than a separate bulb. The work around for this is to take the wire that powers the hi beam and use it to power the solenoid instead.
Finally to power the side LED lights you can just splice into the parking lights. (either the one that lights the amber strip or the other small bulb to the side of the low beam bulb).
So yea, it's quite a bit of work to get everything working. It might be easier just to make a new harness since at this point you're really only using the connector to the ballast.
