Brake Boosting FTW!!11
Old 10-10-2010, 01:47 PM
  #81
midz350
midz350's Avatar
Update.
Apparently, with the 07 HR's you would only have to tap the "122 pin" to brake boost.
I hope that helps the HR's fellows.
Old 09-09-2011, 01:07 PM
  #82
ace32x
ace32x's Avatar
Originally Posted by Hal@Dynosty
No, it is pin 122 on an 07 Z. Also, an 07 Z has pin 126 which is the cruise control brake signal, which needs 12v if brake is released (opposite of brake switch 122). I am not sure if the ecu cross checks those.
bumping an old thread!
so where is pin 122 located by chance? gonna tap it today
Old 09-09-2011, 01:33 PM
  #83
ace32x
ace32x's Avatar
and also, witha base model with no abs or traction control do you still have this issue? i never tried brake boosting on my stock block setup so i wasnt able to check : /
Old 09-09-2011, 03:14 PM
  #84
Blackbird CPV35
Blackbird CPV35's Avatar
Glad to see my 3 year old thread is still alive lol
Old 09-09-2011, 04:36 PM
  #85
ace32x
ace32x's Avatar
lols
Old 09-09-2011, 04:56 PM
  #86
midz350
midz350's Avatar
Here you go:
Also, it has nothing to do with ABS, TCS or VDC. Its the ECU telling the engine to cut power.IIRC
Old 09-09-2011, 05:02 PM
  #87
ace32x
ace32x's Avatar
Originally Posted by midz350
Here you go:
what i figured just wasnt sure, ty sir! so is that the plug above the fuse box or somewhere else? havent gotten under the dash to thoroughly yet
Old 09-09-2011, 05:30 PM
  #88
midz350
midz350's Avatar
No, its the ECU harness.
Old 09-09-2011, 05:31 PM
  #89
ace32x
ace32x's Avatar
o gotcha sweet deal !
Old 09-09-2011, 07:37 PM
  #90
ace32x
ace32x's Avatar
hmm, was looken through it and i think i found it lighting is **** in my garage, but is it the gray wire on the the 122 pin location on the corner of ur harness midz?
Old 09-09-2011, 08:54 PM
  #91
midz350
midz350's Avatar
I really don't remember the wire color, I tapped in the Haltech patch harness.
The word "gray" in that pic is to describe the color of the clip itself not the wires.
Old 09-10-2011, 07:32 AM
  #92
str8dum1
str8dum1's Avatar
dont go by wire color, unless you have your specific model year FSM.
the ecu harness shows which pin is 1 and so forth. just count over to pin 122.
Old 10-08-2016, 10:22 PM
  #93
Juztin
Juztin's Avatar
Sorry to bump an old thread, but I have an 07 HR, and it sounds like I need to put a switch on PIN 122 to briefly allow brake boosting.
Question though, it sounds like I can expect to have my Cruise Control go out from time to time due to the switch on PIN 122 to BB eventually being caught by the ECU. I would expect to hit the BB switch, BB then do a run to 150 or so mph and then brake and hit the switch again to disable BB.
But it sounds like even if that is done relatively quickly in the span of a highway pull, I can still expect eventual CC being disabled until reset by Cypher/Consultant II? Just want to confirm for those that do it. I could use BB to help me deal with some nitrous LSx's on the highway that keep getting the jump that can't be reeled in due to the immediate NOS hit vs the turbo spool.
I like my creature comforts, but might be a necessary evil to get a Cypher/CII to clear it after some nights of highway pulls.
11-01-2015 05:25 PM
samansharif
09-25-2015 12:31 PM
Quick Reply: Brake Boosting FTW!!11
