Car won't accelerate
Old 09-26-2011, 09:29 AM
djamps
djamps's Avatar
Originally Posted by 350Z400rwhp
For me a utec.
I got limp mode all the time with UTEC even through multiple units. It's something you pretty much have to live with. Switched to Osiris and no more limp.
Old 09-26-2011, 11:12 AM
krivera6950
krivera6950's Avatar
Originally Posted by djamps
Need to know the codes before making assumptions. I too thought my TB was the problem but it wasn't in both cases (happened to me frequently on two occasions).
What EMS?
I'm running uprev on my car
Old 09-26-2011, 11:16 AM
krivera6950
Originally Posted by CTZ860
Krivera how did they install hose on ur wastegate wrong?
Well I have a tail wastegate and the hose should be run to the port on the side, when they put it back together they put it on the top port which prevents the wastegate from opening. The mechanic was driving it when the headlifted and caused the car to go into limp mode with a 2500rpm rev limit. He said it was a hose he popped when it happened, it never occurred to me to check the wastegate
Old 09-27-2011, 10:26 AM
krivera6950
Finally got error codes for the CEL. Codes were P2135, P0605, P0304. The P0304 looks like it came up because of the excess fuel that was being poured in because the car did not want to start at first and i was getting smoke out the exhaust. I'm going to the shop to pickup a throttle body and pedal sensor to try them out.
Old 09-27-2011, 10:42 AM
jtabraham
jtabraham's Avatar
Why don't you try the ECU reset procedure before buying a new TB? If I recall, momentarily pulling the battery won't reset it.
Old 09-27-2011, 11:13 AM
krivera6950
I'll try a manuel reset before switching a throttle body. My mechanic gave me a spare throttle body and pedal to try out. The reset shouldn't mess with the Osiris tune?
Old 09-27-2011, 11:23 AM
djamps
djamps's Avatar
P0605 is concerning. If I were you I would redo the primary engine ground before anything else. There are two cables on the front timing covers joining to one that connects to the frame rail on the passenger side. Disconnect battery (important!), remove all three ground points, clean/sand down/grease and reinstall tightly. This will effectively reset the ECU as well. See what codes pop up after that.
Old 09-27-2011, 11:51 AM
krivera6950
Thanks for the heads up. will disconnect all and check, clean, and reconnect
Old 09-27-2011, 02:10 PM
krivera6950
Problem seems to be solved
P2135- Bad throttle body. swapped out for another throttle body and car instantly was getting throttle. Drove for about 30 minutes with a mix of cruising and getting on it and no issues.
P0605- seemed to be a lose connection on the battery which i just loosened, pulled off, and then reconnected
P0300 0r P0304- Still getting a code for it but no CEL at all. Car seems to be running fine but a Little bumpy at times. i might have a fouled spark plug. my car does run a little rich at times so it could be tune related
Old 09-27-2011, 03:50 PM
str8dum1
str8dum1's Avatar
304 means you have a misfire on cylinder 4. if its not throwing a light, it was just pending and will go away.
Lucky about the 605. The RAM error and could be fatal. My car had a 605 error last weekend, similiar solution having to do with voltage.
Old 09-27-2011, 04:34 PM
krivera6950
Yea I'm glad it was something simple and not anything serious, just hoping I don't have to deal with the P2135 anymore
Old 06-26-2016, 12:40 PM
Martinbros
Martinbros's Avatar
Originally Posted by krivera6950
Interesting!!! When you would rev did it feel like it was bouncing off the rev limiter at 1500 rpm or did it just accelerate to 1500 and not give any more throttle? In my case i would floor it and it would slowly climb to about 1400-1500rpm but no bouncing off rev limiter effect.
I noticed you said your z used to accelerated very slow 1k-5k rpm even with the gas pedal all the way down. How did you resolve that issue ?? I'm going through the exact same issue ..
Old 06-26-2016, 01:57 PM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
you revived a 5 year dead thread and the person you asked hasn't logged in since 2012
etkms
06-19-2022 06:30 PM
aarrgghh
05-01-2022 11:04 AM
pslamp32
02-08-2017 09:07 AM
AbyteZero
09-22-2015 09:17 AM
RyansZ33
09-15-2015 05:54 AM
Quick Reply: Car won't accelerate
