HELP! Car Wouldn't Start After Motor Swap - Need Reflash?
Old 10-13-2012, 07:55 AM
bb1314
da Terminator!
bb1314's Avatar
Default HELP! Car Wouldn't Start After Motor Swap - Need Reflash?
My Z is/was a 2003 Touring, ATI procharged with an Osirus tune. I just got another motor (also from a 2003 Z) swapped into my car. I won't get into details as to why since it's another long story. The issue now is that my car would not start. It cranks but there's no spark. So we're suspecting that the ECU is what is stopping the car from starting. All sensors are checked and even swapped to brand new ones. From what I was told from a few experienced shops is that a reflash is sometimes necessary especially when the year of the motor and the car itself don't match.
Couple questions...
1. Any idea besides ECU and sensors?
2. If ECU does need a reflash, only dealership could do it I believe?
3. If I get a ECU reflash, I'd lose my osirus tune since the data is stored in the ECU?
4. If I have Osirus tune done at one shop previously, does the license transfer to another shop?
HELP!
Old 10-13-2012, 08:30 AM
seymore4
Professional
seymore4's Avatar
Have your tuner turn off NATS in the Osiris rom and see if that fixes it
The osiris license is stored in the ecu, it transfers with the ecu, any tuner can use it.
Old 10-13-2012, 08:37 AM
Cass007
Cass007's Avatar
Ethan - I think the Osiris Tune may be stored by your VIN or ECU. I think I remember Frank telling me that once you have paid for the flash you can have it reflashed for much less or free. Have you asked him about that?
Hope you are up and running real soon.
Old 10-13-2012, 07:05 PM
djamps
djamps's Avatar
As mentioned in the dup. thread, you don't need a reflash unless you swapped the ECU. Assuming you're still using the old ECU, you've got a bad ECU or an electrical issue such as fuse, grounding or short.
Old 10-19-2012, 04:37 PM
ishyne22
ishyne22's Avatar
Agreed. This has nothing to do with your tune or a reflash. If you did not change ecu or bcm its not the nats stopping you. I would double check all your connections and grounds around your injector and coil wiring harness.
Old 10-19-2012, 04:42 PM
ishyne22
ishyne22's Avatar
Also pull one of your coils to make sure its not getting spark. If it is sparking double check your fuel pump fuse and or fuel pump.
Old 10-20-2012, 01:59 PM
bb1314
da Terminator!
bb1314's Avatar
Here's an update. So towed the car to Nissan and they reprogrammed the BCM? But the car's still not firing up. It's cranking and trying to start but it just would not fire up. While the car was at Nissan, the tech was able to get some read when the car was attempting the start and the timing was at -7 which is supposed to be WAYYY off. He said that could be the reason.
1. Does that -7 timing during crank mean anything at all? Variables fluctuate so I'm not sure if that really is the issue. The seller of the motor basically swore by his motor that it was running 100% before it was pulled with no issue.
2. Is the timing completely controlled mechanically or it has something to do with tune (keep in mind I am supercharged and running Osirus tune)?
3. Mechanic is gonna check coilpacks and spark plugs again to verify that there is spark. Any other suggestions?
4. Could someone let me punch him in the face just because?
Old 10-21-2012, 11:31 PM
djamps
djamps's Avatar
Make absolutely sure the flywheel is aligned properly. There's notches along the edge which trigger the crank sensor and control timing. If it's not clocked correctly it will run poorly or not at all. Common mistake for mechanics unfamiliar with VQ's. Giving clutch jobs to the new guy and watching them pull the trans again afterwards is like a hazing ritual at dealers LOL.
Old 10-22-2012, 01:09 AM
wannabuy350z
wannabuy350z's Avatar
here is a series of popular issues that may cause your car not to start:
improper alignment of flywheel
cam teeth not correct
engine timing off
assuming you are using the same ECU before the swap
Old 11-20-2012, 07:43 AM
bb1314
da Terminator!
bb1314's Avatar
Turned out the timing was off because of this...
Old 11-20-2012, 12:57 PM
Resmarted
Resmarted's Avatar
that blows.
Old 11-20-2012, 06:01 PM
djamps
djamps's Avatar
Wow, thanks for the update. How does that happen? Was this left over from something else?
Old 11-20-2012, 06:12 PM
bb1314
da Terminator!
bb1314's Avatar
Not sure how this happened. The seller sounds very legit. He said the car was running fine. He pulled the motor out to put in a built motor. Also that is like not a common part that breaks...
Old 05-06-2015, 11:35 AM
1998yellowstang
1998yellowstang's Avatar
Is there anyway to check if the flywheel is aligned properly without pulling the transmission or motor?
Old 05-06-2015, 01:26 PM
Conway_160
Conway_160's Avatar
http://www.jimwolftechnology.com/wol...tion_check.pdf
Old 05-06-2015, 01:32 PM
1998yellowstang
thank you!
Old 05-06-2015, 02:30 PM
i8acobra
i8acobra's Avatar
Received 1,267 Likes on 1,015 Posts
Easy way to check you flywheel position... unplug the crank sensor. If the motor fires up, but in limp mode, the flywheel is off. If it doesn't fire, that's not your problem.
Old 05-06-2015, 04:53 PM
Conway_160
Conway_160's Avatar
With out my crank sensor, the motor wouldn't even spark.
etkms
06-19-2022 06:30 PM
lolwatbro
10-09-2021 04:58 AM
Juztin
11-22-2015 07:03 AM
SpartanZ32
10-22-2015 09:36 AM
Katie93
09-15-2015 05:57 PM
Quick Reply: HELP! Car Wouldn't Start After Motor Swap - Need Reflash?
