FS: Innovate MTX-L AFR Wideband Gauge & Blitz SBC i-Color SpecS w/ extras
Old 06-10-2015, 12:23 PM
DrivenG
DrivenG's Avatar
Default Innovate MTX-L AFR Wideband Gauge & Blitz SBC i-Color SpecS w/ extras
See Below for Blitz SBC
DrivenG is offline
Old 06-10-2015, 12:25 PM
DrivenG
DrivenG's Avatar
Default Blitz SBC i-Color SpecS w/ extras
This is a Blitz SBC i-Color SpecS P/N 15081
Used this on my TT G35 Sedan which is now stock.
Paid over $1100.00 for the entire set up.
Comes with:
Controller
SBC Brain
Single Valve Boost Solenoid
Miscellaneous Fittings and some Boost line.
All the Wiring for Everything.
The optional Oil Pressure Sensor ($130 add on)
The optional Coolant Temperature Sensor with Greddy Rad Hose Adapter. ($130 add on)
Full 42 Page Install Manual
Asking $550.00 Shipped Conus + 3% for paypal or send as gift.
From Blitzpowerusa.com
All-in-one boost controller with eye-catching graphics and functions.
Accurate boost control is accomplished by high performance solenoid valve.
(NOTE) Spec-R employs Twin Solenoid valve, Spec-S employs the single solenoid valve.
Boost measurement can be choose PSI.
Stunning graphics by full-color (65,000 colors) LCD.
Multi-angle display for various installing position/location (Display can be rotated for horizontal/vertical installation).
Fuel mileage can be displayed. (Instantaneous/ Average/ Sectional)
(NOTE) This product calculates the fuel mileage from our original method using the horsepower output., not from injector duty cycle and/or full tank method. Please understand that this mileage figure is approximate and for reference usage only. Also, following limitations apply:
1.Mileage calculation under idling (stationary) cannot be performed.
2.Under deceleration, there is a difference between actual and calculated fuel consumption. Therefore, instantaneous gas mileage varies from actual gas mileage when decelerating.
3.Average gas mileage is the average value when the main unit is on. (From IGN ON to current) Every time IGN is turned off, the previous data is cleared.
Up to 6 data can be displayed out of 16 kinds of data.
Display items: Boost, Speed, RPM, Power, Torque, Instantaneous gas mileage, Average gas mileage, Sectional travel distance, Sectional average gas mileage, External temperature input (Optional sensor required), External pressure or A/F input (Optional sensor required), External voltage 1~3 (Optional harness required)
(NOTE) Only one temperature sensor can be connected. Either press sensor or A/F sensor can be connected.
Data logger function which can graph measured power, torque, A /F, etc.
All- in one full function model including RPM/Speed MAP control function, peak hold, warning, scramble boost, limiter, record & play.
DrivenG is offline
Old 06-13-2015, 04:04 PM
DrivenG
DrivenG's Avatar
BUMP $700 shipped
DrivenG is offline
Old 06-15-2015, 08:40 PM
DrivenG
DrivenG's Avatar
Bump $650 shipped
DrivenG is offline
Old 06-23-2015, 03:30 PM
DrivenG
DrivenG's Avatar
Bump $550 shipped
DrivenG is offline
Old 06-26-2015, 01:46 PM
DrivenG
DrivenG's Avatar
Bump $500 shipped!!!!!
DrivenG is offline
Old 06-27-2015, 09:19 PM
jonnyidfw
jonnyidfw's Avatar
PM Me please Sir. Thanks
jonnyidfw is offline
Old 07-04-2015, 08:32 PM
DrivenG
DrivenG's Avatar
pm sent
DrivenG is offline
Old 07-14-2015, 10:51 PM
DrivenG
DrivenG's Avatar
Bump
DrivenG is offline
Old 07-18-2015, 10:56 AM
DrivenG
DrivenG's Avatar
Bump Crack head price drop $375 shipped
DrivenG is offline
Old 07-20-2015, 11:22 AM
DrivenG
DrivenG's Avatar
BUMP
DrivenG is offline
Old 07-20-2015, 08:01 PM
yosip1115
yosip1115's Avatar
Originally Posted by DrivenG
BUMP
yup. I want. PMd
yosip1115 is offline
Old 07-23-2015, 08:37 AM
T-dizee
T-dizee's Avatar
still available?
T-dizee is offline
Old 07-27-2015, 02:42 AM
DrivenG
DrivenG's Avatar
Yes it is Bump
$350 shipped
DrivenG is offline
Old 08-18-2015, 02:21 PM
DrivenG
DrivenG's Avatar
bump
DrivenG is offline
Old 08-19-2015, 09:53 AM
DrivenG
DrivenG's Avatar
pending sale
DrivenG is offline
Old 08-20-2015, 09:25 AM
jakyle
jakyle's Avatar
This should be sold to me... can you confirm DrivenG - payment was made yesterday
jakyle is offline
Old 08-20-2015, 01:51 PM
DrivenG
DrivenG's Avatar
Yes sold!!!
DrivenG is offline
bcoffee20
11-19-2015 06:39 PM
RavSpec
12-21-2004 08:01 PM
uplz4588
11-04-2004 07:43 AM
KJ-350
03-22-2003 02:55 PM
Quick Reply: FS: Innovate MTX-L AFR Wideband Gauge & Blitz SBC i-Color SpecS w/ extras
