Hissing noise at idle please help
Old 09-13-2015, 03:30 PM
AbrasiveRaysive
AbrasiveRaysive's Avatar
Default Hissing noise at idle please help
So recently I got an aam angled plenum spacer for my 05. I installed it and one of the plenum bolts won't screw back. I tried using another bolt and nothing. It just won't grab. I put the bolt in and screw it and it just keeps turning. I think I may have stripped the bolt hole and I believe this might be causing a vacuum leak which is causing the hissing sound at idle. My question is what can I do to rethread the hole and get the bolt in? Thanks in advance. Kind of new to this so please bear with me.
Old 09-13-2015, 04:32 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
You'll need to carefully remove the spacer and retap the threads on the hole that is stripped out. If the aluminum is too badly damaged, you may need to use the next biggest tap and a slightly bigger bolt.
Old 09-13-2015, 04:57 PM
AbrasiveRaysive
Thanks for the reply. Now would a shop be able to do that? If not where can I find a tap and die kit and any idea what size I would need? Thanks in advance.
Old 09-13-2015, 07:44 PM
dkmura
dkmura's Avatar
A local machine shop might be able to do this work. Otherwise, you can find tap and die sets at any number of tool supply shops- do a search. You'll have to inspect the bolt for size and thread pitch.
Old 09-13-2015, 09:52 PM
AbrasiveRaysive
Thanks a million!
Obadabot
06-18-2023 11:31 PM
liqalu04
01-02-2022 12:58 PM
11-09-2020 10:27 AM
hulkout
Tuning
09-30-2015 12:33 PM
Quick Reply: Hissing noise at idle please help
