Quit running and can't figure it out
Old 01-17-2015, 08:46 PM
jroc_ortiz
jroc_ortiz's Avatar
Default Quit running and can't figure it out
my Nissan 350 Z was running it cut off cuz it ran out if has gas so I went and put gas and it didn't want to cut on so I thought it was the fuel pump so I went and got a new one and installed it I've been trying to get it on and it wont turn on so I went an got a new battery and its cranking can but its not turning over what can possibly be the problem if anyone can help me out
Old 01-17-2015, 10:43 PM
terrasmak's Avatar
Received 2,292 Likes on 1,652 Posts
Please edit your post to make it legible
Old 01-17-2015, 11:51 PM
jroc_ortiz
jroc_ortiz's Avatar
Default ?
How do I do that
Old 01-18-2015, 01:47 AM
dcains
dcains's Avatar
I'm going to bet you can't. Any takers?
Old 01-18-2015, 03:19 AM
Spike100
Spike100's Avatar
English Translation
My Nissan 350z suddenly quit running as if it had run out of gas. I put more fuel into the car, but it still would not start. I thought the problem might be fuel delivery so I replaced the fuel pump. The car still would not start. I installed a new battery; the starter turns the engine over, but the car still will not start. Does anyone have a suggestion?
Old 01-18-2015, 06:34 AM
Kels88
Kels88's Avatar
FPR, dirty injectors?
Old 01-18-2015, 06:45 AM
KornerCarver
KornerCarver's Avatar
Rather than continue to replace parts that may not be bad, just get the car to a mechanic for a correct diagnosis.
Old 01-18-2015, 07:15 AM
Syner
Syner's Avatar
OP, your problems solving skills are clearly no better than your linguistic skills.
Throwing random parts at a car is not going to solve much.
Old 01-18-2015, 07:43 AM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,261 Likes on 2,319 Posts
Originally Posted by Spike100
English Translation
OHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!! Thanks, Spike. Was beginning to think I maybe had more to drink than I thought last night.
Yeah, I'm going to hell....
Old 01-18-2015, 09:57 AM
fatjoe
fatjoe's Avatar
1. Ran out of gas. - CHECK!
2. Bought parts that are most-likely not the problem. - CHECK!
3. Typed a message that no one understood on this forum. - CHECK!
4. What's next?
Easily turn the key to operate and turn off all accessories in the car. Once everything is off, Turn the key to off and back on to operate. You should hear it go "PPSSSTT". That is the fuel pump priming the system. Repeat it 3 times. After that, try to start the car. Let it crack for about 3 seconds and it should start. If it doesn't, wait 15-30 seconds and retry it. If it doesn't start after attempting over a 3-5 minute time span, you will need to have to have the system bled so it will need to go to a mechanic.
Since you had so much trouble with everything so far, maybe you should simply just take it to the mechanic.
Old 01-19-2015, 09:41 AM
terrasmak's Avatar
I wonder if he actually ran out of gas? Can the OP answer the question, was it 20 gallons to fill the car?
I bet it is a different problem, a problem we will not be able to diag unless the OP suddenly uses an education above 4th grade.
Old 01-19-2015, 04:02 PM
Spike100
Spike100's Avatar
I also doubt he ran the tank dry. The car quit running and he added fuel. When the car wouldn’t start, he replaced the fuel pump thinking the car wasn’t delivering fuel to the cylinders ( I guess.). When the car still did not start, he replaced the battery ( Not sure why he did this.).
The problem is either no fuel mixture in the cylinders and/or no spark.
I’m afraid to say any more than this fearing that I could stimulate another buying spree of unneeded parts.
lapham3
10-07-2022 03:15 PM
07-10-2022 07:44 AM
apex locator
07-23-2021 02:27 AM
04-22-2021 09:42 PM
10-04-2015 07:55 PM
Quick Reply: Quit running and can't figure it out
