today was a bad day....
so today was a bad day for my 2004 350z, i did some work on it with terrible results first i will start with what i did. i changed my oil with motosel 10 30 synthetic and lucas synthetic oil stabilizer and an oem nissan filter. i removed the terrible green underglow that was under the car and in the interior, it was installed by the previous owner, it was spliced into a red wire that ran under the center console (part of the harness that runs under the center console). i also removed a "redline power chip" that was spliced into two of the wires on the MAF sensor. i have taped any wires that have had any cut insulation due to quick splices and as far as i can see i have not messed with anything else.
now the results. when i first took the car for a drive i noticed an immense power drop, it could not have been due to the chip as when i took it apart all i found was one small resistor inside. shortly after it cleared up and drove just like normal again. i was messing around a bit did a couple of donuts and again everything seemed fine. after i went to head back home on my way back from the test drive the "VDC off" light and the "SLIP" light became illuminated and stayed illuminated until i shut off the car. after going inside for a couple hours i had to go out, and this time the vdc and slip lights came on and stayed on again. i also noticed that when i went to use my left turn signal it would flash once and beep (sounded like mario jumping on nintendo) inside the car from the speakers (only once with the flash of the light). so i parked the car for five minutes and started it again. on this short drive (aprox 2mins) same thing with the turn signal, power loss was back for the entire drive (felt like 15% throttle), and vdc, slip, and abs lights were on.
i have no idea where to start with this. any suggestions and feedback are much appreciated!
to the mods: excuse me if this is in the wrong section please move it to apropriate section
it was at the end of a dead end road with no houses in the middle of farm country. i just figured id include it just incase it could have anything to do with the problems im experiencing.
but on a serious note im actually trying to help.. the resistor could have played a role in your car not knowing what the **** was goin on cause it wouldnt allow the MAF to send correct air/temp readings (yes maf's on our cars pull both IAT and airflow duties, 'fore anybody calls me out) and as for the slip/traction lights could be a bad abs/wheelspeed or crank position sensor.
found the problem! completley unrelated to any of the work i had done. the exhaust did not exit past the bumper and melted the taillight wiring causing the wiring to short out. i cut a pigtail off a car at the wrecker, wired it in, and everything worked perfect. i have since extended the exhaust tip and so far everything is back to normal.
^^ Thanks for the update. I had nearly an identical experience almost 40 years ago when I built a Volkswagen dune buggy. An errant exhaust pipe's position fried some wiring causing a big and mysterious problem that required a lot of investigation before I could implement a fix.
