crank no start puzzled.....
on
pulled up all codes on obd2 scanner - u1000 and u1001 these codes are only there because of auto to manual transmission swap so i ignore those codes.
red light on dashboard is solid when key is in on position
nats has been turned off on osiris tune so i dont think bcm, nats antenna applies in this situation....
change to new spark plugs
fuel pump i hear it priming
checked compression the readings are 180 through each cylinder wet test
battery was replaced also
confused........ car cranks but wont start.....
am 100% certain timing marks all matched up on the timing chain to sprockets.....i even redid the timing out of paranoia.....
at the moment my radiator and front end are not attached to the car, and my driveshaft is disconnected i dont think that should create a problem if the car is in neutral in terms of starting the car.....
Whens the last time you replaced cam and/or crank sensors?
I know this is a common problem, Im sure you've checked into this already but had the same thing happen to mine and never threw a code. Worth a shot.
