New ProEFI Knock Control Video
Sound Performance
Sound Performance
Part 1:
http://www.youtube.com/user/Professi.../1/7P9874GRMmc
Part 2:
http://www.youtube.com/user/Professi.../0/kToek26wbXg
__________________
Note: You must have a ProEFI 128 for knock control!!
Part 2:
__________________
Part 1:
Part 2:
__________________
Part 2:
__________________
Thanks for the reponse! So the Lvl I unit does not include a wideband controller correct? (or it does but its external?)
As far as the knock detection, how confident are you guys in it being able to advance timing to the most optimum threshold, especially in the higher RPMs, I just figure with so many different engines out there, especially the built engines, they are all going to sound a little different. Usually the OEM knock control is for safety and not optimum for peak performance.
Very interested in the development of this unit!
Thanks again,
-George
GT Motorsports
Thanks again,
-George
GT Motorsports
I am 100% confident. This computer utilizes the latest knock detection strategies available (same as OEM). The key to this is two things. First it looks for a certain frequency on the sensor determined by your engine dimensions. Secondly and most importantly it looks for knock at the correct times. By this I mean there is only a very small window of opportunity for a cylinder to knock on its compression stroke. The computer monitors the sensor only during this time period and if knock is present it knows exactly which cylinder knocked and will retard that cylinder. By utilizing these strategies the computer can filter out what is knock and what is loose piston noise, open wastegate noise etc.
Hope this helps!!
Hope this helps!!
kinda like you need 500$+ worth of sensors to make the 48pin unit do that neat E85 fuel monitoring.
I would guess that all the 48 pin guys already knew they couldnt actively control knock though. Haltech doesnt do active knock control either, correct? Funny how that 700$ UTEC is the only EMS under 2500$ with active knock control.
Sound Performance
Sound Performance
No, the only difference on the 48 box for flex fuel is the $199 unit that converts the frequency output to the analog output.
Sound Performance
Sound Performance
Yes, it has always been the case. 48 units do not have knock inputs, never have had them.
For what the 128 system costs, (starts at $2500ish) no other system offers anywhere near the features. Hell a motec system gets you for an additional $2500 to add knock control!! And theirs is NO WHERE near as sophisticated as the ProEFI. Combine this with trac control, boost control, adaptive learning, launch control, meth control etc and the ProEFI 128 is a bargain. Every supra system that I sell is a 128 unit!!
i knew it monitored the knock sensor....
excellent!
I forgot that any non-flex fuel car would need that 370$ sender, my bad...
We know you sell 128's for the Supra's, so how come its not the one getting sold majorly for the VQ's since its has alot of critical functionality.
excellent!
Sound Performance
Sound Performance
excellent!
excellent!
I really do not know exactly why the 48 unit was pushed more than the 128 for the Z. I suspect it was a pricing thing. It seems that the Z guys freak out when you tell them an EMS system is $2800 and the supra guys dont. Maybe they are just used to paying alot for things!! That combined with the fact that supra guys can add the proefi system by itself to their already turbocharged car while the Z guys are adding it to a build of engine, fuel turbo kit etc. If that makes any sense!!
Other than knock control, the only other thing you really can't do with the 48 unit is the wheel speed traction control although it will be able to as soon as Jason gets the can input to read off the factory can signal.
No other EMS's out there have knock control that is anywhere near the sophistication of the ProEFI. Most are just noise monitors with no frequency or time based monitoring at all. Systems like that (AEM, Haltech etc) without frequency filtering, have too much background noise to see small or moderate amounts of knock at all. And any loud drivetrain noise can set them off as knock too.
I really like knock control when it works as it should. Unfortunately other than the Motec and the ProEFI systems, none of the knock control out there is very good at all. For those systems always tune on the conservative side!!
Your comment about tuning conservative for "those systems" with "noise control" rather than true knock control is a bit off target though since even Jason said you should NOT tune to the point of knock and you should NOT rely on the ProEFI's knock control to allow that practice (since knock has to occur in order for it to be detected and damage may occur regardless of the EMS attempts to mitigate it).
What can the end user tuning software adjust for knock control? It comes ready for the stock VQ engine? I guess I should ask first, does the end user software work for the 128?
That's interesting considering how much knock control was hyped up in the original discussion thread. The only contention I've ever had with the ProEFI has been the deceptive marketing practices (whether it was intentional or unintentional). I wonder how many current ProEFI 48 users knew that the unit never even had knock detection, let alone control? Why couldn't all the ProEFI discussion clearly separate the features of the 128 and the features of the 48 units so that the consumer could make an informed choice? Elaborating on the features of the 128 unit and then promoting the 48 unit because of its low price is just wrong.
yup, nice list there
http://www.proefi.com/productlist_pro128ecu.php
alot of pro128 info for the G/Z also
http://www.proefi.com/proefiresults.php
granted 2800$ is alot of money on top of building your car. That's a good explanation. Being a dealer, is that what you find even after you explain the differences between the 2. I mean active knock control is pretty crucial for most builds. Whats an extra 800 bucks on a 30k bill
^ +1, seriously. The amount of useful information is overwhelming. LOL.
It's called bait and switch. The tactic is reprehensible.
I've probably spent more time reading about the ProEFI than any of your users or would be proponents (except maybe Larry and Tom!). Those guys seem to be the only ones with integrity that post in support of the ProEFI. At least Larry provides facts and straight answers to questions. You have been added to my ignore list (along with Jorge and Eric, so don't bother directing a reply to me).
What is your deal? Are you incapable of going on ProEFI's website and READING the feature list that is there for BILLIONS of people to read? When you pull out the Sunday paper and look through the ad's, what is listed in the ad's? The most expensive fully loaded stuff? Or the least expensive most affordable stuff? No one is hiding anything, you are just oblivious to reality.
I've probably spent more time reading about the ProEFI than any of your users or would be proponents (except maybe Larry). That man seems to be the only one with integrity that posts in support of the ProEFI. At least he provides facts and straight answers to questions. You have been added to my ignore list (along with Jorge and Eric, so don't bother directing a reply to me).
All I can tell you about the 48box as a customer is this.....Larry tuned it, I get in the car and start it (like its stock), and drive the hell out of the car, and it acts just like its stock....well except for that slight whistle and the added 600HP
So like I've said before, from a driver standpoint I love that the car acts purely stock.
All the bells and whistles....well thats why my tuner is 20min away
Tom
Tom
Tom
Tom
And Larry, thanks for the reply to the PM - talk to you soon!
