07 HR reflash completed!!
#161
Originally Posted by SOLO-350Z
Incorrect. The G35 sedan last year is 2008. It is now the G37 Sedan for 2009.
And you are right though that the VQ35HR will be able to share parts between the VQ37. But we do know the intake manifolds will not simple bolt on between the engines.
#162
Originally Posted by Profink
Well yeah. Once you get your ECU back give Tadashi a call and schedule to bring your car in. The ECU will still be in its stock form so you can drive around with no issues.
#164
can someone change the name of this thread to "base model z completed" or "about to complete all model z's" im just tired of opening this thread with excitement lol and then just have a dissappointment.. just more complaining lol
#167
07 Nismo Reflash
Just came back from Technosquare. They did a reflash on my 07 Nismo. Tadashi was such a great guy. he made 3 runs. the baseline was 270whp, the first tune showed 285whp and the final tune resulted in 296.5whp/259.2lb/ft. I think these numbers are great. I only have the Nismo Y-pipe. Everything else is stock. i have attached the dyno sheet.
#170
#172
OMG im going crazy i sent in my ecu last week to get the reflash from japan and they haven't sent it to japan yet. I think im going to kill myself if i can't drive my car for 3 more weeks...
#174
#177
Call Tadashi and get the number from the technosquare website. Im pretty sure you can already get the base flash since profink was the volenteer to get the data from japan to the u.s. YOu don't have to wait 3 weeks at all. YOu just pay and Tadashi will flash and tune it for you. Altough i have a hunch that its not avaliable if you want to send it in yet. I think you can only get it if you are local in socal and drive to technosquare. Im about 80% sure cause my convo with Tadashi was last week and i dont' remember 100%. Gl and let us know what is availiable.....when i call him next week to see the progress they have made i'll update if the information i gave out was valid.
#178
I take it this dyno represents the two "after" tunes and not the baseline?
I don't get the 8k RPM redline though. What's the point? it looks like 7500 RPMs is the optimum shift point anyway (With that power curve) to stay as high in the powerband as possible for the most time.
Also, Was this on 91 octane, or higher?
Oh, and what do the AFR numbers look like?
#179
300+ HP will be surpassable quite easily. My peak HP is at 301.7 running on nothing but HFCs and Nismo exhaust. This is on 91 octane.
The point of increasing the redline to 8k is really more to avoid the fuel cutoff at 7500. At 7500 rpm power is already decreasing, but in a race situation where you're approaching a turn, but not quite there yet, if it comes down to shifting at 7500 rpm which will result in a complete power loss during the shift and a loss of speed, or pulling for a couple hundred rpm more before your break for the turn, which would you do?
Obviously this isn't a situation you'd face daily driving, but at least now you can pull all the way to redline without fuel cutoff. Running beyond that speed isn't advisable for more then a moment or two, but its there if you need it. My above situation will only come into play on certain tracks at certain speeds, but if you happen to live in SoCal and go to Streets of Willow, you'll be able to avoid a few unnecessary shifts into 3rd through a lot of the track.
As far as a CEL fix, I don't believe the reflash will do anything to fix it.
#180
Originally Posted by hiz-n-herz
Very promising numbers - It seems 300+ WHP would easily be attainable, even surpassable, with full Exhaust and HFC's.
