Stock Vortech Maps
Is the boost PSI listed there based off absolute or is it differential?
Reason I ask is because I don't see any timing adjustments until 8.5 PSI. If that's the case then people running the stock PSI levels aren't getting any timing adjustments from the stock maps.
System Settings are:
Display Mode: Gauge Pressure
Application: Additional Injector Controller
Output settings are:
PWM Mode: Pressure to 30 Psi /5 vdc FS
Output A Mode: Aux Fuel Pump with abortive start time
Output B Mode: Over RPM and Pressure
Output C Mode: Inj A and B over /latched
Over RPM: 500
Over Pressure: 8.1
Over INJ %: 0
Fuel Pump start pressure PSI: 0
Fuel Pump run time: 0
Fuel Pump startup time: 0
Over RPM: 500
Over Pressure: 8.1
Over INJ %: 0
Vortech also claims that the SS box doesn't control fuel either. Oh well, just trying to understand what the SS box is doing.
Originally posted by jesseenglish
K thanks. So now the question is, why do they even have the SS box if it's not retarding timing at stock PSI levels?
Look at it again my freind..............
OK, I've looked at the timing graph 10 times now. The first time I see it retarding timing is at 8.5 PSI @ 5000RPM
Clue me in, what am I missing?
Change the settings to Vacuum/Pressure and set Over pressure to 1 and the numbers make sense.
Basically its pulling 1 degree at 5,000, 2 at 5,500, 3 at 6,000 and 6 at 6,500 under 7lbs of boost over 7 lbs of boost 6,000 rpm jumps to 4..........8 degrees dosent come in to play untill you hit 9.5lbs of boost, safety feature in case peeps change pulleys i see!!!
well now I can see why enthuzed got 393rwhp...........less timing being pulled and right around 12.5:1 A/F untill he hits 5,000rpm then he dumps fuel to bring it down to under 11.5:1.............very interesting.
Originally posted by zimbo
I certainly wouldn't recommend taking out less timing than the out-of-the-box program! My suggestion for A/F is 12.0 from 3500 to 5500 then drop to 11.5 @ 6500 rpms.
--Steve
--Steve
what about changing the 5,000 to 0 on timing ..............its only 4.4psi??? and at 5,500 retard 1, 6,000 2 6,500 6???????
