Aftermarket engine management systems
Old 02-19-2009, 05:35 AM
  #41
El Verdugo
El Verdugo's Avatar
Tuned a '03 350z with a Greddy TT on Haltech Platinum and the smile on the face of the client told the story. That car is going to be used for drifting and his main reason to be happy was the fact that the car felt as if the turbo was stock from the factory. Throttle response was lightning fast and no stumbles at all thru out the whole power band.
There are many good systems out there. As long as the tuner is good and cares about the over all performance of the car, the results will arrive.
Old 02-19-2009, 06:31 AM
  #42
Dynosty
Vendor - Former Vendor
Dynosty's Avatar
Shakuya88 - You are correct, a standalone would best suit your needs if you are looking to possibly go down the twin-turbo / built motor path. It will grow with you, and provides additional safety features such as overboost protection that are invaluable for a setup like this. My recommendation would be the Haltech Platinum plug and play standalone. This would allow for a concrete tune on fixed axis that make sense (most commonly RPM vs BOOST) with automatically-triggered onboard datalogging of boost, afrs etc. Additionally you would gain outputs such as closed loop boost control with speed/traction reference and a nitrous/meth window switch. Running a Haltech will not cause a CEL by itself, but often with a full build like this other parameters will trip it (example: needing rich AFRs under boost). If you do get a cel, we can turn off specific codes with a vq35de reflash
Old 04-21-2009, 09:48 AM
  #43
DMK
DMK's Avatar
Originally Posted by MI 35th
ProEFI...
YAH for Haltech, cant wait to see how my Z runs with a Haltech.
Are you saying proEFI is not good compared to Haltech?
Old 02-07-2010, 08:25 PM
  #44
Reid@SP
Reid@SP's Avatar
I was suprised to not see more ProEFI votes from the 350Z community!!
Flex fuel, Traction control, i-Boost, OEM-based fuel/ignition/boost compensation, CAN gauge with it's laundry list of features, advanced Knock control capabilities, and multiple failsafes built right in. We definitely are confident with out product and it's obvious why!!
Reid
Old 02-08-2010, 10:46 AM
  #45
str8dum1
str8dum1's Avatar
ya and its a 3000$ EMS.
its already been discussed that there is no knock control on the 48pin and you need an additional module to do flex fuel on the 48 as well...
but the 128pin is a nice unit. too bad there are 0 128pin users on this forum.
Old 02-08-2010, 11:34 AM
  #46
Reid@SP
Reid@SP's Avatar
ProEFI 48-pin unit: $1995 with Flex fuel capabilities (with purchase of Flex Fuel sensor for $459 and Ethanal percentage gauge for $199), I-Boost, and more!!
ProEFI 128-pin unit: $3469 with built in Flex fuel capabilities (with purchase of Flex fuel sensor for $459), Traction control, advanced knock control, I-Boost, and more!!
One other thing I wanted to correct is that the HP Potential on the CAN gauge is the estimated CRANK engine horsepower not wheel horsepower. It is based on the fuel consumption of the motor and is mathematically very accurate!!
It really all depends on what your goals are and how much you are willing to spend. I know that this is a pricey unit which is why we offer two different units. No one ever said Motec was cheap either!
As for no one runningthe 128, is Vlad not on here? He's the owner of the monster G sedan:
http://www.youtube.com/watch?v=_u5-H5PfyqE
Reid
Old 02-08-2010, 01:11 PM
  #47
rcdash
rcdash's Avatar
Reid
The 128 unit is a nice product, but it won't be on par with the Haltech until you have CAN integration worked out so that it can utilize the stock wheel sensor data for creation of maps using wheel slip as an axis. I'm not sure what you can do for traction control without any wheel sensor data, other than adding additional sensors ($$$). The flex fuel and knock control are nice to have though and look well implemented.
Old 02-09-2010, 05:03 PM
  #48
Reid@SP
Reid@SP's Avatar
The 128 does have CAN integration with wheel speed differential if that's what you're asking about. The 48 does not, which is why it doesn't have the traction control.
I'm not sure if I completely answered your question. I will see if I can get Larry to fill in a couple of the blanks on the subject.
Reid
Old 02-19-2010, 01:02 AM
  #49
Reid@SP
Reid@SP's Avatar
ProEFI UPDATE!!!!!
I have just been informed today, that the ProEFI 128 is now in perfect harmony with the stock wheel sensors so the Traction Control system is only a few mouse clicks away from being set up. No additional sensors needed!!!
Reid
Old 05-30-2010, 04:57 PM
  #50
sk tam
sk tam's Avatar
any ecu under 1000$ for beginner??
Old 01-25-2011, 06:02 PM
  #51
C-unit
C-unit's Avatar
has anyone used E-manage Ultimate for NA tunes?
also is it able to disable the immobilizer?
Old 01-25-2011, 06:45 PM
  #52
Sharif@Forged
Forged Performance
Sharif@Forged's Avatar
It cannot disable the immobilizer.
Old 01-25-2011, 08:20 PM
  #53
C-unit
C-unit's Avatar
^ thanks..I've read that they can do cam phrasing or is that for V-manage only?
Old 01-25-2011, 08:24 PM
  #54
Sharif@Forged
Forged Performance
You need V-Manage to do cam phasing.
Old 10-03-2011, 11:22 AM
  #55
djamps
djamps's Avatar
This thread is in desperate need of updates.
Old 06-06-2012, 04:59 PM
  #56
cnz
cnz's Avatar
Are there any new products available these days for us Z folks? any updates or input on past products from tuners and drivers?
Old 10-09-2014, 12:48 AM
  #57
jdjesse
jdjesse's Avatar
can someone fill me in on what ems they would recommend, I'm building a 3.8 stroker and running a single turbo with 272 cams. best bang for the buck?
Old 11-29-2015, 07:24 PM
  #58
AK Eyes
AK Eyes's Avatar
As far as I can tell UpRev has a monopoly on 350Z FI tuning these days. Is that the case? I'm (slowly) building up a parts inventory for a single turbo build on an 06 uprev VQ35DE. Just wondering if I have any other options for tuning after its built....
Old 11-29-2015, 09:20 PM
  #59
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
^are you on glue?
Haltech has released multiple plug & plays and further more stand alones, AEM just released the Infinity series, Link has the G4+, Vipec has a i series, not to mention emanage and uprev...plenty of options, welcome to the forum and please use the search button...
07-10-2022 07:44 AM
04-22-2021 09:42 PM
sales@czp
09-23-2019 03:30 PM
350z82
10-01-2015 06:25 PM
SharX59
09-27-2015 09:23 AM
Quick Reply: Aftermarket engine management systems
