Unofficial Enkei Wheels Thread
Old 04-22-2015, 10:06 PM
  #2361
terrasmak's Avatar
Received 2,296 Likes on 1,653 Posts
Okay so I tried researching but I couldn't find what I was looking for. So those that are running Enkei Rpf1 with brembos, what are your specs? If you guys have pictures might as well post them too
Obviously I don't believe you searched, it's not like facebook here, you can easily find many years worth of RPF1's. Then you may also notice the Motorsports section where plenty of cars also run RPF1
Old 04-23-2015, 09:36 AM
  #2362
slow7
slow7's Avatar
just scroll down you'll find it
Old 04-23-2015, 03:20 PM
  #2363
AffyliatedZ
AffyliatedZ's Avatar
New Z owner here... Just got an Interlagos Fire Roadster and looking to get some Enkei TSP6 wheels in gunmetal. Here are the specs I'm trying to get:
Front: 18x8.5 25mm Offset
Rear: 18x9.5 15mm Offset
I plan on using the stock tires:
Front:
Offset: +30mm
Tire: 225/45/18
Rear:
Offset: +33mm
Tire: 245/45/18
I'm not a pro when it comes to wheels and tires - will these specs work with the stock tires? how are the offsets? Opinions/comments/recommendations are welcome.
Appreciate the help!
Enkei TSP6
Old 04-23-2015, 05:36 PM
  #2364
Spike100
Spike100's Avatar
^^ The 245/45-18" tires are out of specification on a 9.5" wheel and will be slightly stretched on the rear. That stretching will probably make the wheel gap look larger. Go with a 275mm tire when your rear tires wear out.
Old 04-23-2015, 06:21 PM
  #2365
AffyliatedZ
Thanks - I figured. I do plan to get new tires before the winter so I'll keep that in mind. Any input on the offsets?
Old 04-23-2015, 06:55 PM
  #2366
mr. sparco
mr. sparco's Avatar
Personal preference, I prefer 10.5 +15 square setup but 9.5 +15 works.
Old 04-23-2015, 10:31 PM
  #2367
JoseValencia27
JoseValencia27's Avatar
Your offsets are on point.
Old 04-24-2015, 05:23 AM
  #2368
AffyliatedZ
Thanks all.
Old 04-26-2015, 10:46 PM
  #2369
zyou8er
zyou8er's Avatar
Default Need help. Enkie RPF1 17X10 +18
Will this offset clear the front calipers on 06-08 Base? Thanks.
Old 04-27-2015, 08:10 PM
  #2370
mr. sparco
mr. sparco's Avatar
Yessir, looking for a pair myself.
Old 05-05-2015, 05:47 PM
  #2371
zyou8er
zyou8er's Avatar
Default Sweet!
just bought a set of them for 220 a piece
Old 05-27-2015, 10:05 PM
  #2372
superlim9
superlim9's Avatar
here's my 17x10+38 with 275/40 square. 12.5mm spacer in front 10mm in rear. not lowered though
Old 05-30-2015, 05:13 AM
  #2373
IanP
IanP's Avatar
RPF1 18 x 9.5/18 x 10.5 ET15
Old 05-30-2015, 05:33 AM
  #2374
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
Looking good Superlim. Almost ready to pull the trigger on 18s, car came with square Konig 8.5 X17 at plus 40. Looks awful, mb I'll follow you and get spacers till the new Bridgestones are done.
Old 06-01-2015, 04:15 PM
  #2375
superlim9
superlim9's Avatar
i did Arp Studs and Slip on spacers from z1... but i do track it so i didnt want any chances with bolt on spacers. but yeah you need to change those wheels.. lol. Once i get my coils in I might try 285s... not a problem in the back but the front will be iffy. benefit to 17s... the rpf1's only weigh 15.5 lbs
Old 06-01-2015, 09:33 PM
  #2376
JoseValencia27
Enkei T6S wheels
Feel like this needs to go on here... 9.5 all around +15 offset 245/ 275
Old 06-02-2015, 07:04 PM
  #2377
mr. sparco
mr. sparco's Avatar
Not bad reminds me of grams.
Old 06-08-2015, 04:36 PM
  #2378
NA&CH
NA&CH's Avatar
Enkei owners unite All four z's present had enkei rpf1 18x10.5 square... Only one had the nerve to run a different tire...(roca)
Chris
The following 2 users liked this post by NA&CH:
jhc (07-25-2015), superlim9 (07-26-2015)
Old 06-08-2015, 04:44 PM
  #2379
jhc
jhc's Avatar
SuperLim,
Thx for the input.
Ian plays peek-a -boo and looking good!
NA & CH- man who took
"Best Track Car" @ ZdayZ. The honor waz mine, sir! Nice machine.
JC
Old 06-08-2015, 06:06 PM
  #2380
vtchang
vtchang's Avatar
my god... those fenders.... I need it now. Where can I buy them?
Quick Reply: Unofficial Enkei Wheels Thread
