need help with wheel fitment for 20inch rims
on
im loooking to buy lexani staggered LSS-10 rims.
20 inch but i want as deep of a dish that i can get in the rear. what is the best wheel fitment for a 20 icnh rim. offset and if i will need spacers???
thanks alot
thanks alot
on
These are questions that you are going to have to get with the manufacturer about, it is impossible for any of us to say what would work for you if we don't know what (wheel specs) i.e. width, offset etc... that you are working with. I would have to say that if you are going with a 20" wheel, you should be fine with a 20x8.5-9 (FRONT) and a 20x10-11 (REAR). You are more than likely getting a 2-3 inch lip in the front with a 4 inch lip in the rear which should be sufficient. As far as the offset is concerned, with these specs, you don't want it to be too high, I say keep them below +20 if all possible, but this is something like I said before that you are going to have to work out with the manufacturer. If all goes well, and you do it right, you wont need spacers. Homework is key... Hope this helps.
Ok first off, Lexani????
Second, You can easily fit a 20x9.5 and 20x11 given the offsets are correct. You could probably even fit a 20x10 and 20x12 if the offsets are perfect and you're willing to do a fair share of fender/suspension work. I'm willing to bet that Lexani doesn't make wheels this size with the offsets needed and they cater to the...ahem...ghetto market. I would look it up, but quite frankly I do not want to go to Lexani's site as what has been seen cannot be unseen. The fact that you want to put Lexani's on a 350z is bewildering.
As far as below +20 offsets...I'm not sure if I can agree with that as this is the setup (20x9.5/20x11) that I have. While iForged doesn't release their offsets, I've roughly measured them out to be about between +20 to +25 front and rear which is pretty flush (read: not stupid flush) and experiences light rubbing during full suspension compression dips and turns, and that's with cut and rolled fenders. Unfortunately I don't have equipment on hand to measure any more accurately than that. I'm running 245/275's which has a slight stretch front and rear, with enough room that I could probably fit a 255/285 combination as well. Any lower offsets than that and you're going to have to do a good deal of fender pulling on top of a roll and/or extreme tire stretching.
Please revise your thought of putting Lexani's on a 350z. **** would probably weight 40+ lbs per rim and look retarded while doing it.
on
Administrator
OP, I wish you luck on you're search, even though I predict this topic to head south fairly quickly.
I will leave you with this note though, please refrain from creating a 4th thread on 20inch wheels. Keep all you questions related to this topic in this thread only. A 4th thread will result in time out in the sand box. Enjoy the boards and happy surfing...
My350z staff,
VO
My350z staff,
VO
on
well sorry about the lexani's, just link the wheels...lol
thats why im tryin to figure out what to do, and lexani does make them in 20by10 and 20by8.5 just dont know the offsets.
thanks for the help
thanks for the help
on
well sorry about the lexani's, just like the wheels...lol
thanks for the help
thanks for the help
Just cause they make them doesn't mean you have to run them. Leave the bling bling crap wheels to those pimpin the gold teef n huge gold chains.
on
Please don't put that garbage on your Z. Everywhere I go here there's some retard wearing a baseball cap sideways doing the limp wrist in his POS late 80's caddy wearing 20" Lexani rims and it makes me want to take an infant to a football field and punt it through the field goal.
