FAQ: Official wheel "SPACER" thread!
Old 10-24-2014, 06:42 AM
  #1221
JERZ350
JERZ350's Avatar
Damn, looks like it BARELY clears the brembos
Old 10-24-2014, 06:58 AM
  #1222
Phenom
Toasty
Phenom's Avatar
Received 1,382 Likes on 990 Posts
Originally Posted by Viridian
Okay so I think I'll just try them on, most likely not like them, thm sell them, what's the offset id want for 18x8's
You don't want 18x8's at all. You should at a minimum go with 8.5 front/9.5 rear. More appropriate than that though would be 9.0 front/10.0 rear or even 9.5 front/10.5 rear. Offset for those would be anywhere from about +10 to +25 ish depending on the width.
Old 10-24-2014, 08:46 AM
  #1223
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
another popular setup is 18x9.5 +15 on all corners
i run 18x9.5 +23 in front, and 18x9.5 +15 rear
Old 10-24-2014, 08:58 AM
  #1224
clubhopper
clubhopper's Avatar
You f*ked up. We all make mistakes. Fix the problem by selling those wheels. I don't agree with making stuff works that doesn't.
Old 10-24-2014, 09:03 AM
  #1225
Viridian
Viridian's Avatar
Yeah I definitely f*cked up and it really sucks...
Old 10-24-2014, 09:04 AM
  #1226
craig12895
craig12895's Avatar
The Enkeis on the front actually had a 10mm spacer because they didn't clear
Old 10-24-2014, 10:16 AM
  #1227
SQuaLZ
SQuaLZ's Avatar
Since you bought them new you can't return them for the correct offsets?
What wheels are they anyways?
Old 10-24-2014, 11:31 AM
  #1228
iideadeyeii
iideadeyeii's Avatar
People typically run 25mm rears and 20mm front for stock 18x8 +30. You're going to need 30mm fronts and 35mm rears!
Old 10-24-2014, 11:32 AM
  #1229
iideadeyeii
Sell the wheels. Take a loss since that money would have gone to spacers anyways
Old 10-24-2014, 11:40 AM
  #1230
craig12895
craig12895's Avatar
You should be able to return the wheels. A while back I bought two different wheels to see what I liked in person more. Ended up returning one and buying the other three without any issues
Old 10-24-2014, 03:30 PM
  #1231
Viridian
Viridian's Avatar
Problem is I got then off Craigslist and they're tsw brooklands
Old 10-24-2014, 03:33 PM
  #1232
Viridian
Viridian's Avatar
I could probably sell then easily, if I don't like them, at the local car meets to someone in a mazda6 or something without taking a hit in cash
Old 10-24-2014, 08:00 PM
  #1233
Waiz
Waiz's Avatar
Not worth the effort OP, sell them to someone with a TSX or Accord
Old 10-24-2014, 09:10 PM
  #1234
bad boyz
bad boyz's Avatar
Do you have any pics of the wheels just would like to see them out of curiousity!
Old 10-26-2014, 10:30 AM
  #1235
zedsdeadbaby
zedsdeadbaby's Avatar
i have work meisters s1's
19x9.5 +12 245/35
19x10.5 +10 275/35
i want the fronts to poke out more. just not sure if the bolts will protrude when i put a spacer on. was thinking to ad a 10 or 15 mm spacer.
also i would like to add a 10mm to the rear to get to 0 offset.
am i going to run into any problems. im low and not afraid to run some more camber. and yes my tires are beefy lol
Old 10-26-2014, 06:29 PM
  #1236
HRpowered
HRpowered's Avatar
This is mine with OEM wheels Tanabe gf210s and 25mm all around I also have like 14mm on each rear side added by a the dual caliper setup. I know for my Z I would rather have run 30mm up front. Just my 2 cents for folks spacing OEM wheels. I am running stance rear camber arms with lockouts and SPC toe bolts as well.
Old 12-18-2014, 01:29 PM
  #1237
SoonStanced350z
SoonStanced350z's Avatar
I have varrstoen es6 19x9.5 all around with i believe +22 offset and was wondering what kind of spacers should i run. I was thinking about 25mm in the rear and 20mm in the front but was worried about protrusion. Just wanted to get an input from you guys since you seem to be experienced with spacers and this is my first time using them.
Old 12-18-2014, 01:51 PM
  #1238
SoonStanced350z
Unhappy Which spacers should i get??!?!? help
I know there are other posts about this but i just want some help on what size spacers i should run on my Z. I have Varrstoens ES6 19x9.5 all around with +22 offset all around I believe. At first i was thinking about 25mm in front and 30mm rear but now I'm thinking about 20mm in front and 25mm in rear. i'm also running 245/40 tires in the front and 255/40 tires in the rear. i'm worried that the front will have protrusion and was wondering if i'd need to buy extended studs.
Old 12-18-2014, 02:59 PM
  #1239
JTeeAre
JTeeAre's Avatar
The rule I follow is a spacer 20 mm or higher will NEED extended studs.
Also since youll get extended studs youll need open end lug nuts.
So just put extended studs on all corners and save the future headaches youd get if you DIDNT put extended studs.
Old 12-18-2014, 05:06 PM
  #1240
SoonStanced350z
i read on one of the threads about spacers that you didn't need extended lug nuts unless you bought spacers 25mm or higher because the OEM Z studs are about 24mm so a 25mm spacer would cover them? this is so confusing. so you recommend extended studs all around ?
Quick Reply: FAQ: Official wheel "SPACER" thread!
