Time Attack Setup
Old Mar 11, 2007 | 07:10 PM
Mr Nismo's Avatar
Mr Nismo
Default Time Attack Setup
Hey guys, I wanted to post a thread to find out what your thoughts n' opinions on this set up are.
Im going to be running..
Tires:
245/35ZR-19 93W PROXES 4
295/30ZR-19 100W PROXES 4
Wheels:
VOLK TE37 TIMEATTACK 19x9.5 22mm offset
VOLK TE37 TIMEATTACK 19x10.5 22mm offset
Will i have any issue's with this setup with the fender, coils, breaks..etc...
also what are your opinions on it? i drive a 06 black enthusiast.
Thanks for your time
Old Mar 11, 2007 | 07:13 PM
twenzel's Avatar
twenzel
You'll probably have to run a bit of camber but all I have to say is enjoy the understeer... I would have gone with at least a 265 in front.
Old Mar 11, 2007 | 07:15 PM
Mr Nismo's Avatar
Mr Nismo
i can still change the tire, i havent gotten them yet. Those are just what im told to get... mind if i ask why those tires instead?... (no idea what im talkin about with tires)
Old Mar 11, 2007 | 08:21 PM
teamsprock's Avatar
teamsprock
by running a skinnier tire in front than in the back you are only going to make the car have more understeer. the earlier suggestion of using a 265 tire in front will decrease the size diffrence of your tires between front and back thus making it have less understeer. If you would like I am sure some one will elaborate more on understeer for you if you are unsure what I am talking about. My two cents... I run the same size tire front and back and IMHO the car drive ten times better... again that is just my opion make your car drive like you want it to or look for that matter! Sick wheel choice by the way!
Old Mar 12, 2007 | 07:06 AM
twenzel's Avatar
twenzel
What sort of power level are you at? If you are under 400whp, I wouldn't go any wider than 275 in the rear simply because a 295 will actually make you slower due to more rotational mass and more resistance from friction.
I would honestly run 255/35/19F, 265/35/19R if you are at stock power levels. The 265/35/19 is roughly 0.3" smaller overall diameter than the stock 245/45/18 which will aide in acceleration. This difference shouldn't be large enough to mess up the TSC/VDC/ABS systems.
Old Mar 12, 2007 | 07:22 AM
zman1910's Avatar
zman1910
Most people on this forum stick to a 245/275 combo or a 255/285 combo. These combos will provide the best balance and will be 'stock-like' while still increasing the amount of rubber on the ground.
If you are only looking for straight line traction feel free to put on any size tires. But if you plan on cornering or tracking the car you'll run into some issues.
The ideal and most stocklike is a 245/275 combo, but you'll have a stretched look to your rears running a 10.5" rim. My suggestion would be a 255/285 combo for your setup...GL
Old Mar 12, 2007 | 11:07 AM
MR_X's Avatar
MR_X
I run 245/35-19 on the same sized rim up front. it looks odd because the rim has no protection since the tire is pretty stretched. My rear tire is 265/30-19, VDC is driving me nuts right now. I'm about to get new tires for the rear. Thinking going 265/30-19 front and 285/30-19 rear.
Old Mar 12, 2007 | 01:44 PM
GQ 350z's Avatar
GQ 350z
Do 255 in front...I'm running 295/30 in rear.
Old Mar 12, 2007 | 02:05 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Time Attack TE-37 19x9.5 +22F 19x10.5 +22R
TOYO T1-R 255/35/19F 275/35/19R
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
