18 front 19 rear?
Old Nov 30, 2004 | 03:22 PM
skank-a-holic's Avatar
skank-a-holic
Default 18 front 19 rear?
Has anyone put 18's on the front and 19's on the rear with aftermarket wheels?
Input please!
Pics?
Old Nov 30, 2004 | 06:32 PM
EdgeOfSanity's Avatar
EdgeOfSanity
it isnt a mucle car, dont do it. It really doesnt look right on newer cars anymore.
Old Nov 30, 2004 | 07:16 PM
kcobean's Avatar
kcobean
If you have VDC, you have to keep the ratio of front/rear circumference within about 3% of stock to keep from pissing off the VDC system. Therefore, you have some constraints.
On the track and performance wheels using 225/45-18Fronts and 245/45-18Rear, the circumferential difference is 2.23 inches (fronts are smaller than rears).
If you were to go with a tire size like 225/45-18 front and 275/35-19 rear, you'd have a difference of 1.89 inches. This .34 inch variance from stock is probably ok, but the difference in sidewall height (front would be 5 mm taller than the rear) is going to look a little odd.
Additionally, you're very likely going to seriously change the handling characteristics of the car with the differential sidewall roll front and rear.
I personally wouldn't do it.
Old Nov 30, 2004 | 11:54 PM
skank-a-holic
Thanks for the info... more curious then anything else. I as well was a Vette owner, 1998 & 2002 C5 and the 18 rear and 17 front on those got me thinking.
I am going with the Axis Milano 19" wheels, staggered
Old Dec 1, 2004 | 02:31 AM
ttsupra94's Avatar
ttsupra94
You can do it. There was someone on here that had 20" rears and 19" front with axis seven mods. It does look a little odd. It looks awesome on muscle cars but kinda out of place on our cars i think.
Old Dec 1, 2004 | 02:44 AM
lowrider's Avatar
lowrider
I dissagree. The combo of 18s in front and 19s in back would work out very well. With 245/40/18 and 275/35/19, the sidewall height would be constant front to back, and the factory stagger would remain.
The Corvette has done this since the advent of the C5 (17s and 18s). The C6 has 18s and 19s.
IMO, this is an excellent way to go, and if I were to do it over again, this is the path I would choose to follow. Again, IMHO, 19s are just to big for the front, and the ride suffers as well as the wheel and the suspension being more susceptible to damage from imperfect roads.
Lou
Old Dec 1, 2004 | 03:25 PM
FLZ's Avatar
FLZ
Not an engineer, or physics buff but, my 2000 C5 had 18s in the rear and 17s in front.....And that's factory from chevy........
Old Dec 1, 2004 | 04:33 PM
DragonGcoupe's Avatar
DragonGcoupe
Well if the Carrera GT can have 19 fronts and 20 rears.. then sh*t..
Old Dec 1, 2004 | 07:24 PM
Risk's Avatar
Risk
....ooohhh let me tellya story bout a man named Jed.....poor mountaineer barely.....
Old Dec 1, 2004 | 10:55 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
YOu can do it with no problem...
If you go 18x8.5 / 19x9.5 the tire sizes needed will have to be...
245/40/18 / 275/35/19
Tire diameters are the same as stock / nismo wheels (which work with VDC with these diameters)
If you like the look go for it!
Its weird because 19" rears can sometimes be less expensive then 18... eh eh
Old Dec 2, 2004 | 12:01 AM
skank-a-holic
interesting... theres got to be a pic out there somewhere!?!?
Never knew that about the Carrera GT
Obadabot
Jun 18, 2023 11:31 PM
