Oil Level
Old Nov 30, 2004 | 07:49 PM
crazygideon's Avatar
crazygideon
Default Oil Level
So decided to go to the dealer for my 7500mi oil change @6400mi . When I got home and checked the reciept, they charged me for 4 quarts. I checked the dipstick and the oil level is about 1/4 of the bar between L and H . I know the manual states 5quarts, but where exactly should the oil level be for 5 quarts? I'm hoping they didnt underfill.
Old Nov 30, 2004 | 07:54 PM
zzz350's Avatar
zzz350
the 909 is heard from. I don't know what to tell ya, but the car does need 5 qts of earl.
Let me ask another question, do you sport a mullet?
Old Nov 30, 2004 | 10:08 PM
mike952's Avatar
mike952
I measured this many times. Optimal (usually dead center on dipstick) is 4.5 quarts. This is with a filter change. There is always oil left inside in varous areas, including the bottom of the pan.
Old Dec 1, 2004 | 05:16 AM
King Tut's Avatar
King Tut
You mean you guys can actually read your dipstick. I know I can't. I just heat the car up, change the oil making sure I let it all drain out, change the filter, and fill er up with 5 quarts and don't worry about it. Just watch your oil pressure and if it drops or acts strange then you might be low on oil. As for the 4 quarts thing. They might have just wrote that accidently since the majority of cars take around 4 quarts.
Old Dec 1, 2004 | 04:40 PM
mike952's Avatar
mike952
It's very difficult to read..but since it has grooves, if you put it up to a light and move it back and forth...you will eventually see a very faint line separating the oily from the non-oily side.
It's hard...but I could not resist knowing the oil level for sure....and after I confirmed this after two or three fillups, I stopped checking and simply use the same amount of oil every time.
I suspect, 5 litters put's you at the 75% of the range, and 4 puts you at the 25% of the range...it could be a wider spread though.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
