Brakes Question?????
Old Dec 1, 2004 | 10:25 AM
nandoarc's Avatar
nandoarc
Default Brakes Question?????
Guys I need some comments on this. In the past couple months I've having brakes issues, brougt the car to the dealer twice and they could not hear anything. I took the car to a regular shop and they told me need new front breaks and rotors...I was in a hurry because I don't have any other car, so they did it for me....$400, this was like a month ago, now I brought the car for part replacments (foot rest pedal) and told them to check the noise brake again, they said we want to keep the car for testing in the morning...so I agreed. Just got a call from them they said I need a rear brakes now ...$219. How can the brakes go so fast, my car only has 12,474 miles? Do the warranty apply to this??
Any comments....
Old Dec 1, 2004 | 10:42 AM
King Tut's Avatar
King Tut
Warranty doesn't apply to wear items which includes rotors and brake pads. Have you taken off the wheels and visually inspected the rotors and pads yourself? That would be the first thing I would do before letting someone tell me I need new brakes. What kind of brake noise are you getting?
Old Dec 1, 2004 | 10:44 AM
roydiculous's Avatar
roydiculous
1. What kind of brake issues did you have? Squealing during stopping. Problems with braking distance, etc etc?
2. Do you have the Brembo or non-Brembo brakes?
3. Did the shop give you your old pads and/or rotors? Seems to me you got scammed.
4. Rear brakes wear out about 1/2 the speed of front pads.. due to the braking power being around 70/30 front/rear.
5. And if you DO need new brakes, do yourself a favor and install them yourself. It's $60 per set of brake pads... and it's a 30 minute install.
Old Dec 1, 2004 | 10:53 AM
nandoarc's Avatar
nandoarc
Thank you guys for the replies.
I think it was a service bulletin for this..
Service Bulletin Num : 03114
Date of Bulletin: DEC 3, 2003
Component: BRAKE SYSTEM
Summary: REDUCTION OF FRONT BRAKE NOISE WHEN BRAKING IN REVERSE
I told them about it but they can not replicate this, in the meantime I hear this every morning when I backup my car from the driveway at slow speed (not even 5 mph). Also when I'm getting close to a traffic light and start appling the brakes I can hear it just when the car is about to stop...same noise. Any ideas...
Old Dec 1, 2004 | 11:10 AM
roydiculous
Um... are you getting brake SQUEAL when you are slowing down? Is that the problem? Have you ever bed in your brakes? I bet that's the issue:
Please read Pad and Rotor Bed-In Theory, Definitions and Procedures at http://www.stoptech.com/technical/
Old Dec 1, 2004 | 11:13 AM
kcobean's Avatar
kcobean
While it may be possible to burn out pads in 12K miles, I can't imagine needing rotors replaced in this same window unless for some reason they have warped. Like RD said, I think you got scammed.
As for the sound at low speeds, it's very common to get some squeaking in this car under 5MPH. A forum search will reveal many people who have this problem. Is that what you're hearing is squeaking? If so, try some squeal stop on the pads/shims.
Old Dec 1, 2004 | 11:26 AM
nandoarc's Avatar
nandoarc
"While it may be possible to burn out pads in 12K miles, I can't imagine needing rotors replaced in this same window unless for some reason they have warped."
How realistic this can be "burn out in 12K", its possible. I did have one front rotor warped, sorry my bad. My concern is the longevity of the brakes pads. A cousin of mine works at Infiniti dealer and he see a lot of this with Infiniti cars and they repleced with out questions ask, specially if you have 12K miles or less.
I have a 03 Touring, got it in Dec 02.
Thanks again.
Old Dec 1, 2004 | 11:47 AM
upinya's Avatar
upinya
I have an 03 Touring purchased Nov 02 and just replaced the OE pads at 47,000 miles. I replaced with Hawk pads.
Old Dec 1, 2004 | 11:55 AM
dnguyent's Avatar
dnguyent
20k miles, and two rather mild track days, and I still have about 1/4 of my front pads left. I'm not hard on the brakes on a day to day basis, since my driving consists of 70% freeway and 30% city, but 12k miles sound absurd.
If you're a very aggressive driver, and wait till the last minute to apply your brakes (you'll know who you are because your passengers always look nervous), then I can see how full time city driving may burn through a set in under 12k miles.
Otherwise, it sounds like your mechanic took advantage of you.
Old Dec 1, 2004 | 12:09 PM
nandoarc's Avatar
nandoarc
"If you're a very aggressive driver, and wait till the last minute to apply your brakes (you'll know who you are because your passengers always look nervous)"
lmao.....
I barely drive my car, I commute to NYC for work....
I'm in the phone with Nissan, let see it they pick the tab....
Old Dec 1, 2004 | 12:20 PM
nandoarc's Avatar
nandoarc
Well not luck, but F.Y.I. Brakes are cover under warranty 12month/12K miles which ever comes first.
Thanks again.
Old Dec 1, 2004 | 11:25 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Unfortunatly there isnt much room on the factory OEM Non Brembo Rotors to turn them... So rather then turning them and only replacing pads you need to get new rotors and pads...
Thankfully stop tech has OEM Replacement rotors that can take alot of abuse and be turned and then re used again like new...
samansharif
Sep 25, 2015 12:31 PM
