component speakers
Old Nov 6, 2002 | 05:57 PM
dan350z's Avatar
dan350z
Default component speakers
I'm thinking about focal 165k components and am wondering how much should I expect to pay? Also do I need to run new speaker wire and is it difficult and where have you all mounted the crossover
Old Nov 6, 2002 | 06:35 PM
Vincey2kr1's Avatar
Vincey2kr1
I'm in the process of installing my focal 165k's right now, I've seen them on EBay brand new w/ warranty for $249-$259 plus shipping. From what everyone says at the car audio forum its okay to run with the stock wires, which i'm doing. The wires are a bit thin though. You'll need to pick up a 1"spacer ring for your speakers so that the magnet will clear the window, I bought one at Best buy for $12. I'm mounting the crossover on the door, theres plenty of room between the door and panel. I mounted the tweeter in the stock location, its a bit larger then the stock tweet but will fit.
Old Nov 6, 2002 | 07:01 PM
imntcrzy's Avatar
imntcrzy
so the 165k will fit in the door with a spacer?
Old Nov 7, 2002 | 02:16 AM
Vincey2kr1's Avatar
Vincey2kr1
Yup and make sure you dynomat the doors cause it Rocks!!!
Old Nov 7, 2002 | 04:22 AM
Subw00er's Avatar
Subw00er
a guy on ebay named indoaudio sells focal cheap!
Old Nov 7, 2002 | 04:37 AM
Sabre's Avatar
Sabre
Where and how much of the door do you dynomat? How much material do you need for two doors?
Old Nov 7, 2002 | 05:00 AM
Zoro's Avatar
Zoro
Default it's a kit
They sell door kit's I'm not sure but I think there about $90.00.
My installer recommends doing the insides of both the outer and inner panel.
Old Nov 7, 2002 | 12:59 PM
imntcrzy's Avatar
imntcrzy
look around the net and buy dynamat by the case ..... for about $100 you can find enough to do the whole car
Old Nov 7, 2002 | 01:37 PM
roberto350z's Avatar
roberto350z
i installed jl audio xr components and they sound awesome. You can find then for $250 online, which is a fabulous bargain.
Dynomat like crazy. The doors are SOOOOo boomy they really let the bass rock. I also used 16 gauge new speaker wire, but the process is sketchy getting through the rubber sleeve. If you want to do the thing professionally, the only solution is to disconnect the electrical harness going from the door to the body and then drill THROUGH the plastic to feed the wires. You really have to be willing to demolish the unused part of the harness. Ill show pics if you want, but it does run the risk of screwing up your door electronics if you are not handy with a drill. Also, youll need to make a wood spacer 1.25 inches high so the speaker can clear the window (install the speaker with the windows down). In addition youll need to file down one of the plastic nubs holding the speaker grill in to be able to get the door back on.
I put my crossover in the area behind the driver onto an MDF board that holds all my amps and crap
Ill do pics later if you want!!
Old Nov 11, 2002 | 07:56 PM
Subw00er's Avatar
Subw00er
pics please!
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
