UNdersteer/Oversteer
Old Feb 6, 2005 | 05:54 PM
the7ferret's Avatar
the7ferret
Default UNdersteer/Oversteer
A lot of people say that the Z suffers from understeer.
However when I take a corner quick I feel oversteer vs. understeer. Is this just how I drive? or is thier something wrong with my Z.
Its really ovibious when I make a U-turn.
Old Feb 6, 2005 | 06:18 PM
thawk408's Avatar
thawk408
There is nothing wrong with the way you drive. The reason cars understeer is because the front breaks traction before the rear does. The Z has norrower tires in the front, thus it is prone to understeer.
Old Feb 6, 2005 | 06:43 PM
the7ferret's Avatar
the7ferret
I understand what causes understeer and that the Z is prone to it. But why am I experienceing oversteer? When driving agressively but not wild
Old Feb 6, 2005 | 07:40 PM
thawk408's Avatar
thawk408
Maybe something to do with the tires you have.
Old Feb 6, 2005 | 07:41 PM
GaryM05's Avatar
GaryM05
How fast are you turning the steering wheel when you approach a turn? You can definitely invoke oversteer in this car if you turn the wheel in an extremely rapid, snapping motion vs. using a smooth, controlled motion.
Also, having your tires filled to a non-standard PSI can affect the handling, as can extremely hot or cold temperatures.
Old Feb 6, 2005 | 07:50 PM
the7ferret's Avatar
the7ferret
Im not snapping the wheel, I try smooth motions. Maybe I am invoking it and just not realizing it; and I just checked my pressure at its at 32psi cold.
ps. OEM tires
Old Feb 6, 2005 | 08:54 PM
mofoz's Avatar
mofoz
during my autox i definetly realized the understeer that was present. didnt really notice it on the street, even with spirited driving.
Old Feb 6, 2005 | 09:59 PM
Z BOY's Avatar
Z BOY
Default Re: UNdersteer/Oversteer
so your back end breaks free easily?
Old Feb 7, 2005 | 06:42 AM
julian's Avatar
julian
not exactly. the elise is balanced but has narrow tires in front. it's all in the suspension tuning.
Old Feb 7, 2005 | 08:02 AM
ANXIOUZ's Avatar
ANXIOUZ
Going only a few MPH while cranking the wheel all the way...and then gunning it will let the back end kick out a bit. No doubt.
But taking a smooth curve at 60mph is a different story.
Old Feb 7, 2005 | 11:51 AM
HanZolo's Avatar
HanZolo
When people say the Z understeers, they are talking about high-speed corner entries. Power-on oversteer that you're seeing is normal.
superlim9
Aug 26, 2015 07:46 AM
dtoma_esq
May 25, 2008 07:41 AM
dtoma_esq
May 24, 2008 11:16 AM
FALLEN1z
Apr 15, 2007 08:54 AM
