Tire pressure monitor question
Old Nov 17, 2002 | 04:02 PM
Gendo Ikari's Avatar
Gendo Ikari
Default Tire pressure monitor question
Will replacing wheels/tires or just the tires alone require some hookup for the Tire pressure monitor to still work?
Old Nov 17, 2002 | 04:35 PM
all_bark's Avatar
all_bark
the tire pressure monitors are sensors that are hooked into the air inlet valve stem on the tire. They are attatched/unattatched by using a tool that screws it into the valve stem. The tool is on the outside and the sensor is secured on the inside of the tire.
Whatever the case, after you remove and reinstall the tire (and or rim) you probably have to go to the dealer to have the computer re-establish itself with the sensor. That will probably be required to get it working again.
The dealer also has instructions on how to remove and reinstall on another rim if you are switching out.
Hope that helps.
Old Nov 17, 2002 | 04:40 PM
NowUZme's Avatar
NowUZme
If you haven't already, search for the forum for posts about this and you will find some.
From what I have read: tires are no problem. But I guess for wheels you may need to make sure that they can handle the stems that come with the stock Z (Performance/Touring/Track).
Like I said, search the forums and you will find some info about this.
Old Nov 17, 2002 | 05:11 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
Hope that helps.
you dont need to go to the dealer.. just make sure sensors are put on the same corners...
this is per the service manual... but you are right... if one were to get stolen, or damaged... the dealer has the procedure to re-program a new sensor to the appropriate location.
m
ps.. also, txstyle had his removed and put on new rims.. no problems arose.
issyz
Jul 2, 2017 03:04 PM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
kyin
Oct 15, 2015 05:54 AM
rizzla
Sep 29, 2015 03:58 PM
