oil pressure.....whats normal?
Old Nov 23, 2002 | 11:58 AM
Scanman's Avatar
Scanman
Default oil pressure.....whats normal?
My Z now has 200 miles on it and I has wondering what you guys are reading in the way of oil pressue. At idle when hot my car reads just below the second line (25 or so ?). At WOT I get above 60 psi. Does this sound about right?
Thanks, CS track
Old Nov 23, 2002 | 07:52 PM
kevinkatz's Avatar
kevinkatz
mine does about the same
Old Nov 23, 2002 | 09:20 PM
Radian's Avatar
Radian
Mine seems to be a bit lower when idle.
The gauge shows half way between the "30 psi" and Zero. I have to assume this is 15psi when the engine is fully warmed up and idling at 750rpm.
Old Nov 24, 2002 | 12:40 PM
dragonbz99's Avatar
dragonbz99
mine is at liek 30 psi idle i get pretty far over even at 4000 revs is somethign wrong?
Old Nov 24, 2002 | 04:53 PM
uf300zx's Avatar
uf300zx
All of your oil pressures sound normal. The pressure can vary depending on outside temperature and oil temperature. On really hot summer days in my Z32 I'll have a oil pressure reading of about 20-25ish and cold day it will idle about 30-35 ish. The pressure should go up during WOT and with increasing engine speed, but shouldn't go above 90 psi (mark above 60).
MAsSIVrOOM
Oct 20, 2023 10:50 AM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
