How do you reset the ECU?
Old Jun 26, 2005 | 07:34 AM
CajunZ's Avatar
CajunZ
Default How do you reset the ECU?
I'm putting my stock cats back on I was told I might need to reset the ECU.
How do you do this?
Old Jun 26, 2005 | 08:37 AM
DavesZ#3's Avatar
DavesZ#3
The easy way is to disconnect the battery for 24 hours. The quick but hard way is to try the reset procedure:
http://www.technosquareinc.com/350reset.htm
Old Jun 26, 2005 | 09:39 AM
CajunZ's Avatar
CajunZ
Disconnect neg or pos side of battery?
Old Jun 26, 2005 | 09:41 AM
DavesZ#3's Avatar
DavesZ#3
I don't believe it matters. If I remember correctly, the negative has less stuff on it than the pos side.
Old Jun 26, 2005 | 09:43 AM
CajunZ's Avatar
CajunZ
Thanks, As soon as I can get off of work (don't know when that will be) I can finish putting my stock stuff back on.
Old Jun 26, 2005 | 09:01 PM
Zaw's Avatar
Zaw
does it have to be 24hr?
Old Jul 2, 2005 | 08:58 PM
ZlleH's Avatar
ZlleH
What is the advantage of reseting your ECU? Only thing I heard is to make the rev limiter a little higher to 7400 rpm...
Is there any other advatages?
Old Jul 2, 2005 | 11:10 PM
sokudo9l6's Avatar
sokudo9l6
you're suppose to disconnect the negative side first before you touch the positive side. When resetting the ECU...just disconnect the negative. Have it sit there for 10-15mins. I really doubt that you have to leave it disconnected for 24hrs.
Old Jul 3, 2005 | 05:35 AM
DavesZ#3's Avatar
DavesZ#3
You're thinking of "reflashing the ECU" like Technosquare or AAM does. That is a reprogramming of the settings. Reseting the ECU is like a reboot. It returns the ECU to some default state.
Old Jul 3, 2005 | 02:08 PM
Stabber's Avatar
Stabber
Yes
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
