Ticking/clicking sounds from rear right
Old Jul 4, 2005 | 12:41 PM
cruzin's Avatar
cruzin
Default Ticking/clicking sounds from rear right
Hi guys,
I bought a 350z in Feb, now 8,000 miles. The last month or so, I'm hearing a ticking/clicking sound from the rear-right, at first it was just when i went from dead stop, now it's more often, even shifting into higher gears, always just when the car is accelerating.
Anyone else have this? Is there a TSB for this? Where can you get the TSBs from? If it does have a TSB, I'd want to bring the car and TSB with me to the dealer to get it fixed quickly.
Thx,
-- Pete
Old Jul 4, 2005 | 12:53 PM
itburns's Avatar
itburns
You know, I had the same EXACT problem at about the same mileage. Then I hydroplaned and crashed my car at about 10,000 mi, and I haven't had the problem since. I'm not trying to scare you, it's just that the problem seemed to resolve itself. I forgot all about that until I read your post. The hydroplaning was just a coincidence. I have 14,000 mi now.
Old Jul 4, 2005 | 12:55 PM
zand02max's Avatar
zand02max
That'll fix the clicking noise,
Old Jul 4, 2005 | 12:59 PM
350z bra's Avatar
350z bra
i know what will fix ur problem. BLAST UR MUSIC!!! hehe
win
Old Jul 4, 2005 | 06:29 PM
vincei's Avatar
vincei
Mine is getting fixed for the same problem right now. There is a tsb for axle clicking here:
http://www.infinitihelp.com/Ownershi.../NTB04-065.htm
I have a 2003
Old Jul 4, 2005 | 06:38 PM
The Brickyard Rat's Avatar
The Brickyard Rat
Dealer just replaced my rear axels per TSB from Nissan.
Old Jul 4, 2005 | 08:15 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
yes, bring to your dealer. There is TSB for it. Seem like after passing 8K, the problem will surface.
Old Jul 5, 2005 | 10:19 AM
VO...'s Avatar
VO...
Administrator
Mine does the same thing. I have 20k miles. I only hear it when pulling out of my garage at a dead stand still. It sounds like something is inside the rim and falling as the wheel turns. It isn't the APS either. Had that checked already.
Old Jul 5, 2005 | 10:22 AM
boma's Avatar
boma
It's axle ticking! Make those dealers fix it.
Old Jul 5, 2005 | 10:26 AM
Fletch69z's Avatar
Fletch69z
My 03 makes a clicking noise at really low speeds from the front when I turn the wheels. Like when parking or backing out of a parking space. Sounds like low steering fluid or something to me. I took it to Nissan and they said they couldn't replicate the noise! Anyone else had this problem?
Old Jul 5, 2005 | 10:30 AM
bixby's Avatar
bixby
Guess I need to turn down my stereo and see if I notice a tick.
Old Jul 5, 2005 | 10:35 AM
tractng's Avatar
tractng
Guys,
This might be something else, but the gas tank makes a lot of noise. The gasoline movement is very loud.
Anybody notice this?
Tony
Old Jul 5, 2005 | 10:43 AM
JasZ's Avatar
JasZ
I seem to get a click whenever I let out the clutch and hit the gas in 1st and 2nd. Could that be the same thing?
Old Jul 5, 2005 | 11:05 AM
arlingtonz's Avatar
arlingtonz
That is when mine seems to be making the noise also, I think I am going to call my dealer and have them take a look at it.
Old Jul 5, 2005 | 12:29 PM
VO...'s Avatar
VO...
Administrator
Mine had the same problem! It happened when I first got the car. Took them a week to figure out what it was. It only happened when I made a turn, for example at an inner section. They had to put some type of sensor on the suspension itself. Then they drove around in my car and the sensor monitored unusual vibrations within the suspension. They pinpointed the trouble and fixed it. Unfortunately I never asked them what the problem was.
Old Jul 5, 2005 | 12:32 PM
VO...'s Avatar
VO...
Administrator
No, that is something different. I get the same clutch noise too. It sounds like someone dropping a heavy metal plate onto another, huh? Man, now that I think about it my car has alot of unusual noises. Time to take it in. I also hear the squeaking noise when I push in on the clutch pedal. Sounds like wet shoes squeaking on a floor. Anyone know what that is?
Old Jul 5, 2005 | 12:34 PM
bio911's Avatar
bio911
rocks stuck in the tire tread?
Old Jul 5, 2005 | 02:28 PM
Fletch69z's Avatar
Fletch69z
Mine sounds sort of clunky when I'm turning into a parking place and the sounds are directly proportional to when I'm turning the wheel. I don't know but I hope they can figure it out. Later,
Fletch
Old Jul 5, 2005 | 07:01 PM
Aggro_Al's Avatar
Aggro_Al
They did the rear axle TSB on my car and it fixed it. No clicking noise any more.
Old Jul 5, 2005 | 07:05 PM
Aggro_Al's Avatar
Aggro_Al
Fletch
Have the dealer check to see if your left and right front upper link bolts are torqued to specification. They've been know to cause a clunk if they aren't speced right.
