Replacement RE 040's
Old Aug 31, 2005 | 08:02 AM
LouD's Avatar
LouD
Default Replacement RE 040's
Just returned from a 900mi trip after having recall alignment and two new replacement front tires. Noticed that new front tires are not running as hot as before (fronts running 1-2 psi lower than rear at highway speed and temp...psi front and rear used to be comparable) and a 1.0-1.5 mpg loss in fuel economy. Started trip with all four tires at 36 psi cold. Anyone having similar experience?
Old Aug 31, 2005 | 08:06 AM
BZ350's Avatar
BZ350
I just bought my 05 Z with the RE 040. Should I be going back to the dealer asking for new tires?
Old Aug 31, 2005 | 09:05 AM
Fletch69z's Avatar
Fletch69z
Wierd, don't know.
Old Aug 31, 2005 | 10:18 AM
King Tut's Avatar
King Tut
WTF mate? Where did you get that idea? This guy is just being a little oversensative about his TPMS and his fuel mileage. Both of those numbers are well within any kind of error threshold. It could just be the difference in tread height from the new fronts and the old rears causing more heat in the rear tires and a higher psi and a 1 or 2 mpg loss in fuel economy could be caused by damn near anything.
Old Aug 31, 2005 | 11:15 AM
Is it possible that your confusing "tire pressure" and "temperature". An under inflated tire will run hot (a major cause of tire failure). A properly inflated tire will run...well...at the proper temperature.
You’d like to increase fuel mileage a bit? Run plus one or two pounds “cold.”
Old Aug 31, 2005 | 11:49 AM
BZ350's Avatar
BZ350
Calm down I just didn't read it close e-nuf
Old Aug 31, 2005 | 01:06 PM
King Tut's Avatar
King Tut
Pressure and temperature are directly related. As the temperature increases so does the pressure. So when he sees that the front tires are running lower on pressure he is assuming that it is due to them running colder.
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
