Lsd
Old Oct 18, 2005 | 05:12 PM
Escobar's Avatar
Escobar
Question Lsd
Has anyone driven or owned a base Z without the LSD and then driven a Z with it? Is there a big difference. I have the base model and it seems to be kinda hard to drift it on occassion due to no LSD. Do you think I could just get one out of a totalled Z in a junkyard or just buy a aftermarket one, thanks
Old Oct 18, 2005 | 05:27 PM
Z_Driver's Avatar
Z_Driver
Master
Yes, if you step on it in a corner the Base Z will light up the inside wheel a lot more. This is because it is getting dis-weighted. The Enthusiast Model and up will move the car forward thus making your track times and handling better. It can also still burn rubber going around a turn but, it is moving the car forward at a faster rate because some of the traction is getting transferred to the outside wheel.
Enthusiast Model up have VLSD. I'm buying a Nismo LSD. They are are better and you can adjust the slip bias without taking them out and adding shims like other clutch type LSD's on the market. I think that will come in handy on track days.
Old Oct 18, 2005 | 05:43 PM
AmiiricanMade's Avatar
AmiiricanMade
how much is the nismo LSD?
Old Oct 18, 2005 | 05:45 PM
Swiffer's Avatar
Swiffer
@ $1000 + installation
Old Oct 18, 2005 | 06:19 PM
Z_Driver's Avatar
Z_Driver
Master
You can get one right now here for $901.
http://performancenissanparts.com/ca...products_id=59
One of our sponsors. Thank you Performance Nissan !!!
I have seen them as low as $846.
It's one of the first things I'm doing along with Hotchis sways and Koni Sports when I get back to work.
I have a couple of people that do a great job installing these for $350-400.
So, worst case = $1,000 + $400 = $1400. For Nismo LSD installed with stock gear set. If you want to go with 3.90's it another $500 or so. I like the gearing the way it is I think. I need a ride in a car with 3.90's however. I might pop for that since it is only a 10% reduction and won't screw up the highway mileage much. Top end will suffer but this isn't a top end car for me.
140-150mph would still be good for me.
Old Oct 18, 2005 | 07:47 PM
Escobar's Avatar
Escobar
Thanks for the reply, 1400 sounds a little steep, I think I may just get exhaust and CAI before, but I definately will prob. get one. Is getting one out of a junkyard totalled enthusiast Z out of the question? Cheaper?
Old Oct 18, 2005 | 08:08 PM
Z_Driver's Avatar
Z_Driver
Master
Yeah, I bet you could get one for under $500. Then it would be the VLSD not the clutch type and set up would put you at $850. Really you can do the NISMO for around $1250 complete. I think you have a good idea. I just figure if I do it I want the stronger unit that get better traction and is adjustable. However, in my Firebird I stayed with the stock LSD and regeared it and I am quite happy. I really don't see that you can go wrong either way.
I'm just going to bite the bullet and when I can just do it all at once. I have done one thing at a time for years. I figure I got the car for cheaper than expected and I have about 7K to put into it once I secure a job and don't have to use the money for house payments etc...
Old Oct 18, 2005 | 08:53 PM
undRgrNd350z's Avatar
undRgrNd350z
so you're saying my 2006 track comes w/ lsd? how much better is the nismo lsd for drift?
Old Oct 18, 2005 | 10:26 PM
Z_Driver's Avatar
Z_Driver
Master
Should be much better cause you can preload it as you like and it is stronger.
You also get instant LSD action opposed to a liquid that has to react to lock the rear up for you.
You might want to see if someone could set you up a air locker or lock-right for our Z's. That might be even better. I would love get into that sport. Nothing like hanging it out with control.
Old Oct 19, 2005 | 04:53 AM
Escobar's Avatar
Escobar
Interesting, I think the NISMO might be worth it.
Old Oct 19, 2005 | 10:46 AM
Nismo 350z's Avatar
Nismo 350z
The Z isn't a drift car if u are planning on drifting. But the Nismo LSD is a good choice if u TRACK your car. If u want just a street car with a LSD then go with Cusco or Kaaz.
Old Nov 14, 2005 | 04:31 PM
illZ's Avatar
illZ
Why isn't the Z a drift car? I am fully aware of the sport and the car. It works fine. Although the lighter cars are easier to drift, the Z is no slouch.
Old Nov 14, 2005 | 04:54 PM
GhostFace's Avatar
GhostFace
Well the heavy wieght is one of the biggest factors, but other than that...
-There is alot more aftermarket support for, lets say...the 240sx which means, easier to find what you need, and probably at a cheaper price
-you can make a completely drift ready, with tons of nice goodies...for the same price it costs for a bone stock 350z...maybe even 2-3 of them for the price of a Z
-Drifting = lots of crashing and broken parts...ALL THE TIME....again the cheaper costs of the car and parts wins
-you can do basically anything to a 240, ziptie your bumper on, weld something you shouldnt weld, and you wouldnt care at all...cuz you probably bought the car for 1500 dollars, i should know, i drive a 240 that doesnt have paint on the front end haha
-350z's are too new, not as much is known about them as is 240's which have been around for 16 years?
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
