Understeer... what can do ?
Old Nov 18, 2005 | 01:05 AM
alexml's Avatar
alexml
Default Understeer... what can do ?
We all know that the Z drived into the limits gets Understeer, what can do to reduce this ???
yesterday i upgraded my tire pressure and it geted worst, was undriveble
whats the best tire pressure?
Old Nov 18, 2005 | 03:40 AM
paulsmansfield's Avatar
paulsmansfield
Originally Posted by mc350z
believe it or not remove the spare tire.
Ultimately most road cars will understeer, it's safer than oversteer
Old Nov 18, 2005 | 04:38 AM
Vamos_Rafael's Avatar
Vamos_Rafael
thats true, automakers determined the average drivers first reaction would be to brake or lift rather that correct with steering.
i noticed in autoX that with the spare tire removed and less than half an tank of gas. the back end would break loose much easier and changed the dynamocs of the car.
INstall roll bars
Upgrade suspension
Make body stiffer!?
Old Nov 18, 2005 | 04:50 AM
350Z007's Avatar
350Z007
Originally Posted by jvanquish
INstall roll bars
Upgrade suspension
Make body stiffer!?
+1
Old Nov 18, 2005 | 05:02 AM
HarvesterUT's Avatar
HarvesterUT
you can also run equal sized rubber all around
Old Nov 18, 2005 | 05:30 AM
Brake a bit earlier. Give the car a bit of throttle through the turn. This will get some of the weight off the outside front tire.
Old Nov 18, 2005 | 05:35 AM
paulsmansfield
turn the steering wheel a little bit further
Old Nov 18, 2005 | 09:33 AM
mavtais's Avatar
mavtais
Brake drift.
Old Nov 18, 2005 | 09:49 AM
makim's Avatar
makim
learn to drive and know the limits of your car/supsension/tires
Old Nov 18, 2005 | 09:55 AM
makim's Avatar
makim
Old Nov 18, 2005 | 11:02 AM
failsafe's Avatar
failsafe
....for your health
You can also run a stiffer sway bar in the rear.
Old Nov 18, 2005 | 12:03 PM
Kolia's Avatar
Kolia
haha. Fun one !
Old Nov 18, 2005 | 01:13 PM
TanabeUSA's Avatar
TanabeUSA
It's much easier than that guys
The easiest and cheapest way to adjust the handling dynamics of your vehicle is to adjust your tire pressures.
While you can always pick up parts like anti-swaybars (such as ours ) you can easily adjust the handling dynamics with what you have. Adjust front or rear tire pressures in increments of 2psi.
If it's still not performing in a way that you like, it could be your driving techniques and habits.
Once you have a solid foundation on your technique and your car's abilities/dynamics, then you should start modding.
Tanabe Racing Development USA
http://www.tanabe-usa.com
Old Nov 18, 2005 | 01:45 PM
buho62's Avatar
buho62
get a new car(like Ferrari F50), if that doesn't help, get a new hobby.
hiz-n-herz
Nov 13, 2007 06:43 AM
dmoffitt
Jul 20, 2007 06:15 PM
dmoffitt
Jun 20, 2007 02:51 PM
tienlo
May 16, 2005 05:40 PM
