So i need a new clutch...
on
Yea, so alongside the other thread, i'm creating this one to discuss the pricing. The dealership finally gave me a quote: $1,000USD for the clutch replacement (parts + 8 hours @ $80/hr). They're saying that the flywheel probably doesn't need to be replaced, but if it does, that's an extra $1,500USD on top. Question: what can i do to save myself some money? Can i buy the JWT clutch and have a private shop install it? How much cheaper would that be? Or do i have to buy the JWT clutch/flywheel combo? How about getting a private shop to just install the OEM parts? Also, what are the odds of the flywheel needing replacement?
if you been racing or riding the clutch hard, your flywheel might have heat scoring, which you *could* resurface the flywheel if there is enough surface underneath to eliminate the heat scoring..
the jwt clutch would be the better route if you drive the car hard and want the adding grabbing force for your 'spirited' driving.. private shops if you call around will probably save you $100-200... $1000 for a clutch job is a bit high, but thats your dealer. i mean. aftermarket oem replacement clutch is around $475. labor should be only like $300/400.
take it to a reputable import shop and you should be ok..
Parts for clutch and flywheel should be around $800. Labor should be approx 4 hours.
Respect
JET
on
Guys, i need whatever hookups i can find here in Toronto. So if you know anyone, please tell me and i'll call em ASAP!
I'm gonna go with the JWT setup. They want $450USD for the disk/pressure plate, or $750 (another place) for the above plus the flywheel. Do i really need to spend another $300 on the flywheel? I'd really rather not, unless i'll regret it later.
on
Originally Posted by D350Z10
Buy a aftermarket one...jwt clutch and flywheel 700 and can pry get installed for 300 bucks at a 350z shop Toronot... You are pretty close to michigan I can hook you up with my sponser and they will take perfect care of you let me know!
![Smilie](https://my350z.com/forum/images/smilies/smile.gif)
on
Just ordered the JWT disk/plate for $550 incl. express ship to Canada. Expecting to pay around $350 for labor here. Plus towing and misc costs, i'm looking at $1050USD for the whole ordeal.
u cant resurface the oem flywheel. id recommend getting the jwt flywheel with the clutch. r u sure that the oem flywheel is compatible with the disk? call up jason@performance, he would know.
