Noob question about shifting =P
Old Jan 8, 2006 | 02:29 PM
Kabs's Avatar
Kabs
my bad. Insead of doing :P or or =) i do =P
its my thing i guess... i always do it
Btw thanks everyone for the help. I really appreciate it
Old Jan 11, 2006 | 06:05 PM
dragon11689's Avatar
dragon11689
Dont worry man your doing the right thing. Break it in easy for first 1500 miles. Then you can redline it all you want. Keep it under 4k for now. Although I wouldn't go up to 4k either until then.
Old Jan 11, 2006 | 06:15 PM
blackpitbull's Avatar
blackpitbull
For the best gas milage on a Z set your shift indicator at around redline and at every red light drop the clutch and smoke tires. This will cause you to not only waste a ton of gas but also incur future tire costs.
This is what I do and I think you should to ....why? because to worry about gas milage on a sports car is like a hummer worrying about a speed bump at a grocery store -
Old Jan 12, 2006 | 03:06 AM
Kolia's Avatar
Kolia
Babying an engine for its first 1500 miles and then redlining it is not very good.
The 4k limit is only for lengthy periods. Short incursions above it is ok and actually beneficial to the engine and drive train break in.
Old Jan 12, 2006 | 05:21 AM
daytonablu350's Avatar
daytonablu350
i have my shift warning light at the stock setting. I floor it often and i still get 18 miles per gallon. but if i try to get good gas millage i shift at 4000 and get 24 miles per gallon.
Old Jan 12, 2006 | 06:17 AM
jrod1014's Avatar
jrod1014
I regularly shift at 3,000rpm... I feel it is the best balance between fuel economy, acceleration and practicality when driving around town. For the more spirited accels, I rev it to like 4,500 or 5,000 =)
Shifting at 2,500 is like when you're driving in a parking lot... Just wind it up a bit more, the car gets decent gas mileage if you don't constantly have a lead foot.
Old Jan 12, 2006 | 06:34 AM
amsweigart@hotm's Avatar
amsweigart@hotm
Originally Posted by BhashaZ
Try resetting your MPG. I know mine showed 8-12 MPG in the beginning, and once I reset it, it started showing 18-19 MPG. I think it is because it is a rolling average from the last time you reset it.
I currently average about 23.2 MPG. I generally shift at 3000, although I occasionally will go beyond that when I am entering the freeway or trying to pass people up. So my shift light is at 3000RPM because that way I can actually SEE the damn light when I am daily driving. Also, in 6th gear at 80mph, you should be around 3000RPM. It forces me to stay 80mph or under so I have less chances of getting a speeding ticket. Of course, that's not to say that I don't EVER take it above 80, but if I do, it won't be for that long since I get annoyed of the blinking light.
That's what I do LOL!
Old Jan 12, 2006 | 06:54 AM
Gooey's Avatar
Gooey
I normally shift around 3k but screw the break in just buy extended warranty and drive the car like its meant to be
Old Jan 12, 2006 | 07:53 AM
Silkk's Avatar
Silkk
Originally Posted by Kolia
Is your Z a diesel for shifting so low ?
I shift somewhere between 3-4000 rpm and get 22-23 mpg around town.
+1, but I get 24.X around town...
25-26 Highway... (and this is with a few mods)
I shift whenever I please. Usually 3000-4000, but several romps to 6000-6500 as well during a day.
Old Jan 12, 2006 | 12:51 PM
dragon11689
Really? Because I did at times, and thought to myself, "Oh man, I hope I didn't screw up anything". I always varied my rpms and kept it between 2k and 3k most of the time. After 1500, I started going towards 5k, and gradually day by day worked towards the redline. I hope I cleared up what I was trying to say. Just take it easy and don't go overboard with the engine. And definitely don't accelerate quickly. I'm just following the manual. Nissan made it that way for a reason.
Old Jan 12, 2006 | 03:13 PM
JunJTan's Avatar
JunJTan
if you shift below 3k, then i don't think you bought the right car. THIS IS A SPORT CAR.
Old Jan 12, 2006 | 03:48 PM
HighwaySpeed's Avatar
HighwaySpeed
Talking
Shift when she screams!
Old Jan 12, 2006 | 06:19 PM
dragon11689
Just for the break in period. Don't get me wrong. Reread my posts again. I still redline a lot now. No doubt about that. I just like to follow Nissan's manual for best maintenance of the car.
Old Jan 12, 2006 | 06:28 PM
MovingViolation's Avatar
MovingViolation
My shift points depend on my mood. I couldn't care less about gas mileage.
Old Jan 12, 2006 | 07:52 PM
Liz Ahn's Avatar
Liz Ahn
well, i had your same problem when i first got my Z but then i realized it was because i always had my climate control on~ hehehe =P
Old Jan 12, 2006 | 08:04 PM
hue's Avatar
hue
I set my rev meter at 5900 rpms bc I want maximum ponies and I want a warning when I'm getting close to the knock zone. Usually, I give it some juice when there is a nice clearing 4000-5000 rpms. I usually rip the rpms in the 6000 range once a day to get my fix.
Old Jan 12, 2006 | 11:33 PM
lilaznxboi08's Avatar
lilaznxboi08
well you know after you start gasing it hard, under around 3k is normal driving, above that your gona start wasting more gas.
Old Jan 12, 2006 | 11:39 PM
  #38
plumpzz's Avatar
plumpzz
It all depends on the gas..
Exonmobil averages me 15mpg
Sunoco 94 averages me 23-24
BP Amaco averages me 22-23
Denco/Wawa/Raceway averages me 15
All others between 13 (EEK) to 18
I usually put amaco since its best bang for buck.
I shift at 3k usually but occasionally romp it. Also, i dont waste time shifting and i usually stay in high gear unless im passing. Cruise control is your friend.
Old Jan 13, 2006 | 01:42 AM
  #39
Acree's Avatar
Acree
To get good gas mileage, I shift at exactly 2000rpm. Doing that, I've seen 24mpg in the city. It's about the most boring way to drive the Z, but it works!
Old Jan 14, 2006 | 01:46 AM
  #40
mikeg8r's Avatar
mikeg8r
Yes, it's a sports car, but some of us also use this car as (fun) transportation back and forth from work and going out to get groceries and stuff and would like halfway decent gas mileage at those times
That said, I set my shift light at 4800 (which in the manual says is optimal for accel) although I rarely shift then in regular driving. I pretty much let the feel and sound of the engine tell me when i should shift, which is somewhere around 3000-3500 RPM and I get about 16-19 city and avg about 20MPH (it's L.A. what'ya'gonna do?). My numbers always go way up if I can do a lot of hwy driving. If i remember correctly, set @ 4800 your doing a little over 100 before the light starts flashing @ 4300 in sixth.
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
