Torque
Old Jan 19, 2006 | 12:25 PM
The Mike's Avatar
The Mike
Default Torque
Just an off the wall question.. Does more torque for an engine mean it will be able to rev faster and in turn hit its peak horsepower sooner than a similar engine with similar peak horsepower but lower torque?
My reasoning is that with more torque on a wrench.. its easier to turn a bolt... so the bolt moves more quickly either on or off. Shouldn't the same principle apply the an engine? And if you can reach your peakhorsepower faster then... even its its a few marks lower than a competing engine.... you should still be able to accelerate faster right? Oh well... just daydreaming and this came to me... correct me if i'm wrong.
Old Jan 19, 2006 | 12:45 PM
arejohn's Avatar
arejohn
Yep, when you'r outside the hp power band, torque rules.
Old Jan 19, 2006 | 12:49 PM
plumpzz's Avatar
plumpzz
torque is the amount of force your wheels are pushing the ground to push you forward. Hp is the rate at which your engine does work... a higher HP means you can put more torque down to the wheels within a given time.
Old Jan 19, 2006 | 04:20 PM
Kolia's Avatar
Kolia
HP is a factor of Torque x RPM.
So two engine with similar HP rating at same RPM will have the same torque at that RPM.
Otherwise, yes, your reasoning is right
I drove the 2006 Civic SiR. Man it take for ever to rev !
Old Jan 19, 2006 | 07:59 PM
The Mike's Avatar
The Mike
*Just an engine beginner* ..
Thinking of how the pistons connect to the driveshaft with an arm who's length determins the torque that engine has... it circles the driveshaft..... the more torque you have there *larger cirumference* it must rotate around the driveshaft must also mean that the piston would need to be longer/taller which would in turn mean that you would basically have to have more piston displacement to have more torque. UNLESS... and I'm still just speculating... You reduced the radius in the cylinder/piston so that you ended up with tall skinny cylinder for the piston to travel up and down and then you could have a small displacement yet lots of torque. Is that right? heh.. I really should take a mechanics class.... I've just started to sorta get interested in these things.
EnjukuRacing
Sep 30, 2015 06:55 AM
RWDBajan
Sep 17, 2015 04:52 PM
raceboy
Jan 15, 2003 10:18 PM
atcga
Nov 10, 2002 10:45 AM
N4Spd
Jul 4, 2002 10:22 PM
