Too much heat???
Old Feb 22, 2006 | 10:39 AM
Jcolman's Avatar
Jcolman
Default Too much heat???
Is it just my car or does the Z put out too much heat when the heater is on? My car seems like it puts out too much warm air even on the first "click" from off. I like the fact that there is a temp dial but I swear I'm getting 70+ degrees when it should be closer to 65.
Old Feb 22, 2006 | 11:02 AM
MRfire's Avatar
MRfire
Exact opposite for me....
Old Feb 22, 2006 | 11:06 AM
Soccerprep205's Avatar
Soccerprep205
when its not raining... blast the heat and put your windows down...thats what i always seem to find myself doing
Old Feb 22, 2006 | 11:08 AM
The numbers, like those on the thermostat at home, are just guidelines. If you are uncomfortably cold, turn up the heat. If you are uncomfortably cold, turn it down.
Old Feb 22, 2006 | 11:29 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Z's a/c is confusing as hell to me! Why can't you have hot, inside air without the compressor being on? I mean, maybe I don't want to dry the air out and rob power from the engine, breathe noxious fumes from outside, or be freezing.
*musical* You can't always get what you want... *musical*
OK...I need to lay off the crack.
Old Feb 22, 2006 | 11:42 AM
Jcolman's Avatar
Jcolman
I realize that and if I could turn down the heat I would. On my car I go from cold air (heater turned all the way off) to very warm air on the first "click". There is no inbetween unless I also turn on the A/C. This is the only car I've ever had where I can't simply mix outside (cold) air and warm engine air to make a comfortable temp inside.
Old Feb 22, 2006 | 11:43 AM
bbhiznors's Avatar
bbhiznors
when i turn my ac and vent completly off it will turn the ac on full blast from time to time any one else have this issue or is my z possessed
Old Feb 22, 2006 | 11:50 AM
Jcolman's Avatar
Jcolman
Hmmm....I just read the owners manual and maybe I'm doing this wrong. The manual states that the fan control should be in the "auto" mode when using the heater with the A/C turned off if you want to maintain the heat in the car at a particular temp. I'll give that a try on my drive home tonight.
Old Feb 22, 2006 | 12:11 PM
spacemn_spiff's Avatar
spacemn_spiff
+1. I would like recirculate in every option of air.
Old Feb 22, 2006 | 12:26 PM
angelzhope720's Avatar
angelzhope720
I used to turn off the A/C everytime it turns on automatically. I realized my car started to smell like strawberry smoothies and smoke so now I leave it on and my car smells good
Old Feb 22, 2006 | 12:43 PM
freefallin's Avatar
freefallin
I just leave mine in full Auto and it's always comfortable.
I was in Kansas City on business a couple weeks ago and had some crappy Chevy without climate control and it sucked having to always fix the heat.
Old Feb 22, 2006 | 02:54 PM
fireballtaft's Avatar
fireballtaft
I leave my temp dial on 75, and both the other dials on auto regardless of the temp outside, if it's cold outside and the heater is running, the "auto" feature only puts heat out of the feet vents and it keeps it very comfortable inside. If it is hot out, and the a/c is running, then the face vents come into play. Use the temperature gauge and turn cooler if it is blasting too much heat and vice versa if it is blowing too much a/c. Hope that sheds some light on this dilemma.
Old Feb 22, 2006 | 03:16 PM
Santacruzslick
Veteran
I like strawberry smoothies!
Old Feb 22, 2006 | 04:33 PM
Kolia's Avatar
Kolia
Many people do that and wonder why they have fogged windows...
Old Feb 22, 2006 | 06:51 PM
Casanova's Avatar
Casanova
WTF... its summer here in AUS.... aircon is great.... GREAT !!!!
Old Feb 22, 2006 | 07:21 PM
MOOCH10's Avatar
MOOCH10
Fireballtaft, you have yours set at 75? in Florida?
Old Feb 23, 2006 | 03:36 PM
fireballtaft
for the most part, unless i've been doing an active sport and sweating, then i'll bypass the auto feature and full blast the a/c. My OCD also comes into play and i don't like the temp dial hash mark being off center. I also have thin-skin and enjoy long walks on the beach, yet I dislike being sandy; interesting.
Old Feb 24, 2006 | 09:21 AM
Santacruzslick
Veteran
[QUOTE=fireballtaft] My OCD also comes into play and i don't like the temp dial hash mark being off center. [QUOTE]
Haha, I thought I was the only one. My ac always ends up on 75 with the fan at 1/2 way just to keep the lines going straight up. I'm hopeless...
Old Nov 2, 2007 | 02:29 PM
aireq's Avatar
aireq
I have the same problem did you ever figure out how to get this fixed?
If I turn the temp control all the way to the left it turns to full AC. If I barely click it to the right just into the tempurature range it goes to blasting full heat. It doesn't matter if it's 35 or 95 degrees outside.
Eric
Old Nov 2, 2007 | 02:30 PM
aireq's Avatar
aireq
If I turn the temp control all the way to the left it turns to full AC. If I barely click it to the right just into the tempurature range it goes to blasting full heat. It doesn't matter if it's 35 or 95 degrees outside it's always either full AC, or full heat. Turning the fan to auto always results in the fan going to max speed.
Eric
