is mine LSD?
Old Mar 9, 2006 | 10:01 AM
350Zylow's Avatar
350Zylow
Default is mine LSD?
alrite i did a search for LSD and came up with nothing, but this is still probably a repost, so sorry. I have an 06' manual base model and was wandering if it does in fact have lsd, and what exactly lsd does compared to the regular drive. i have no traction control or anything, AND both tires burn when i spin them so it sounds to me like i do have it. But i dont know. Thanks
Old Mar 9, 2006 | 10:05 AM
one350zfan's Avatar
one350zfan
well, every other years base dosen't but i'm not sure about '06. Does it kick to the side when hard shifting into 2nd?
Old Mar 9, 2006 | 10:08 AM
Swiffer's Avatar
Swiffer
Base 06 does not have LSD. If both tires are spinning, you must have been smoking something else.
Old Mar 9, 2006 | 10:19 AM
350Zylow's Avatar
350Zylow
yeah it does move to the side and it also lays down rubber with both tires
Old Mar 9, 2006 | 10:37 AM
yobri's Avatar
yobri
Base still without LSD for '06... included with the models above though.
http://www.config.nissanusa.com/redi...r=2006&lang=en
Old Mar 9, 2006 | 10:39 AM
350Zylow's Avatar
350Zylow
so what exactly is lsd and why do both my rear tires spin?
Old Mar 9, 2006 | 10:42 AM
one350zfan's Avatar
one350zfan
Its kicking to the side because only the left rear tire is gripping(open diff.) Put a few sand bags in the passenger seat and it will help even it out.
Old Mar 9, 2006 | 11:02 AM
Durden76's Avatar
Durden76
If you want to learn more about what a limited slip differential is and how it works, check out this link.
http://www.popularmechanics.com/auto...tml?page=3&c=y
Old Mar 9, 2006 | 11:04 AM
Durden76's Avatar
Durden76
Here's some more info on the subject:
Limited Slip Differentials
What is a limited slip differential?
The purpose of any differential is to allow the drive wheels to turn at different rates from each other. The main reason one wheel has to turn at a different speed than another is that when turning a corner, the inside wheel needs to spin at a slower rate than the outside wheel because the inside wheel follows a smaller arc. If the two wheels were locked at the same speed, one or both of the wheels would have to break traction in order to be able to go around a corner.
Most vehicles come with an "open" (aka "peg leg") differential that basically does its job of allowing the wheels to spin at different rates. The biggest problem with this is if one of the drive wheels slips, an open differential sends more power to the slipping wheel, not less (it is the path of least resistance). This is most noticeable when one is stuck in the snow: one drive wheel will spin, and the other one will just sit.
From a performance standpoint, this means when one is cornering and the wheel on the inside of the turn is being unweighted and begins to slip under power, much of the power will go to it, causing it to spin more, which may cause understeer (a front end push to the outside of the turn) in FWD cars. The wheel on the outside of the turn, which is being weighted and therefore has more traction, does not receive as much power, so the power is wasted on the spinning inside wheel. Also, when launching aggressively off the line, when one wheel begins to spin, it will receive the bulk of the power, causing it to spin more.
Now, limited slip differentials (LSDs)(they come in all different configurations, and not all are called LSDs [torsen diffs for example] but we will call them all LSDs to simplify things) use a mechanical, hydraulic or electronic mechanism to supply power to the wheels that grip, not just the wheels that slip (yes, just like in the Subaru ads). As the name implies, they provide only a limited amount of slip between the driven wheels. So, when cornering, the outside wheel will get its fair share of power, lessening understeer and allowing one to power out of corners better. Torque steer is also lessened, and wheelspin on aggressive launches is minimized.
But the key feature of LSDs is that they still allow the drive wheels on either side of the vehicle to turn at different speeds, which is why we have differentials in the first place. A drag racing trick is to weld an open peg leg differential together so that both wheels are locked and receive equal power. This makes for great drag launches, but trying to go around corners, even very slowly, is extremely difficult, and can break axles as the outside wheels fight the inside wheels.
So the end result with an LSD is better handling and accelleration. And a much lighter wallet if you are buying one for a car that does not have one already.
Old Mar 9, 2006 | 11:29 AM
350Zylow's Avatar
350Zylow
according to the comment above and the popular mechanics page what i seem to have is a limited slip diff. this is just an educated guess and my amature opinion, but my car displays all the symptoms of being LSD. i also called the dealer and they are looking into it.
Old Mar 9, 2006 | 12:07 PM
C-lo's Avatar
C-lo
heres what you do: rev up to 5000rpm and pop your clutch...If you see one black line then you dont, if u see 2 lines then you do...by the way, you dont.
Old Mar 9, 2006 | 12:13 PM
Nexx's Avatar
Nexx
yeah, you have lsd, the nissan magic fairy suddenly decide to bless your base Z and only your base Z with LSD. as much as you would like to fool yourself into thinking you have LSD, sadly you dont. Much like I fool myself into thinking my Z came stock with boost, sadly I dont.
Old Mar 9, 2006 | 12:17 PM
350Zylow's Avatar
350Zylow
its humbling to know that i can come on here, ask a simple question, state the facts, not be a dick and still get flamed. C-lo with a burn out i get 2 tire marks.
Old Mar 9, 2006 | 12:55 PM
ANXIOUZ's Avatar
ANXIOUZ
Well the Base does NOT come with a LSD. Period.
You keep saying that you have it. Then you ask what an LSD is.
If you truly have a Base, you do not have an LSD.
Old Mar 9, 2006 | 01:03 PM
jeeper78's Avatar
jeeper78
Here's what we do to test our Jeeps... jack up the whole rear end, and spin one tire forward by hand. If the tire on the opposite side spins the same direction, you have LSD and it's in working condition. If it spins the opposite direction, it's an open diff. Our stock LSD has clutch packs, and yours is a viscous coupled LSD, but I think it should work the same way.
Old Mar 9, 2006 | 01:05 PM
Durden76's Avatar
Durden76
If you have LSD, then you must have an Enthusiast. Do you have stereo controls and Cruise control on your sterring wheel? If you do, that means you are driving an enthusiast model.
Old Mar 9, 2006 | 01:09 PM
350Zylow's Avatar
350Zylow
i never said i have it, i said i seem to have it but its just a guess. i'm just answering questions people ask, and stating what my car does. How about i just leave it at i dont have LSD and thank you for all of you comments. My mind is now at ease. Safe driving.
Old Mar 9, 2006 | 05:16 PM
HighwaySpeed's Avatar
HighwaySpeed
Exclamation Lsd...
noun
A crystalline compound, C20H25N3O, derived from lysergic acid and used as a powerful hallucinogenic drug. Also called acid.
Old Mar 9, 2006 | 07:41 PM
Casanova's Avatar
Casanova
^^^ This guy is unbelievable... knows his ShiZniTzzz
Paul.
Oct 16, 2015 07:34 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
