There were minor changes mid-year. The most definitive way to tell is your VIN#. Search the forum for details. Also, 2004.5's have knee pads on either side of the center console near the radio, as well as a power outlet under the passenger dash area.
04.5s have a revised suspension with increased rear spring rates and better rear dampers. I believe the roll bars are slightly different as well. Other 04.5 features include kneepads, an additional power outlet, and possibly some minimal changes in the interior plastics. Look for the kneepads, they are your best bet.
If i buy new tires for a 03 that has feathering will they have feathering also?
The unfortunate answer is, it depends. If you go with the OEM tire (Bridgestone RE-040), it's likely (assuming that an alignment didn't cure the car) that the problem will come back. Many people have had success by simply going to a non OEM tire and getting a good alignment.
Well dont most people that get new rims get different tires? or whats so special about the stock tires that one would keep buying them even if they feather?
