who has dynoed their 06's??
Old Mar 15, 2006 | 09:10 PM
Armitage's Avatar
Armitage
Well I would assume by dynoing in the correct gear they might be slightly higher. I think you would see a small gain in HP, but a larger gain in TQ. I would try and go back and see if you could swing a free pass or two in 5th and see what the differences are. And see if they are SAE corrected.
Old Mar 15, 2006 | 09:11 PM
Fa1rLadyZ's Avatar
Fa1rLadyZ
Originally Posted by Armitage
Sorry, blew through the thread too quickly.
Yeah, your numbers are high too because you used a DynoPack. It removes rotational mass of the rims and tires from the equation and raises the results. How much is hard to say... depends on teh weight and size of the rims and tires, but you can probably expect to drop at least 10whp from your plot with them on.
i know that dynopack read higher than dynojet. but from all the dynopack result of 06 i saw on the forum, i think mine is the highest.
Old Mar 15, 2006 | 09:47 PM
Fa1rLadyZ's Avatar
Fa1rLadyZ
plus looks like they did my dyno on 4th... because it went up to 109 mph and 4th gear tops out at 115 mph
Old Mar 15, 2006 | 10:27 PM
SilverstonE-O6's Avatar
SilverstonE-O6
I hit 272whp 261 trq on a dynojet. SAE Corrected numbers would be around 262whp 251 trq I believe. The Mrev plus brought my mid range torque up alot. And yes, the highest numbers came from 5th gear.
Old Mar 15, 2006 | 10:28 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by plumpzz
guys in 287 motors wish they can hit 250whp w/ some mods...ur fine. If u want more torque get the MREV mod...sounds pretty nice and it has good results.
riiiight....I hit 256whp with intake and test pipes back in the day.....
Old Mar 16, 2006 | 07:44 AM
deviljon's Avatar
deviljon
i just want to double check... so on a dynapack, 5th gear is the 1:1 ratio for manual transmissions and not 4th.... right?
Old Mar 16, 2006 | 09:48 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
yes
Old Mar 17, 2006 | 12:58 AM
Armitage's Avatar
Armitage
Not just on a dyno pack, ANY dyno you run the manual should be in 5th gear, the auto in 4th. That is my understanding.
Old Mar 17, 2006 | 03:09 PM
Zquicksilver's Avatar
Zquicksilver
+1
I basically hit 249whp/245tq on my 287 with CAI, SPACER, HEADERS and HFCs, NO TUNE. Temps high 70s, no humidity... same DYNO ^
Zquicksilver
Old Mar 17, 2006 | 08:07 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by Zquicksilver
+1
Zquicksilver
Old Mar 20, 2006 | 11:31 PM
deviljon's Avatar
deviljon
will have more accurate results later this week, car is getting re-dynoed in 5th gear this time, and then dynoed again 3-4 more times to see gains from custom catback system. previous results were sae corrected.
Old Mar 21, 2006 | 04:25 AM
LIdrew's Avatar
LIdrew
Call me a Newb, but won't the same car dyno at different #s on different days on different dynos with different temperatures, etc?? SO how do you REALLY tell how much HP/TrQ you really have?? The only equalizing factor would be to dyno the same car on the same dyno at same environmental factors AFTER doing mods to tell what the gains are for that particular car. I have a hard time believing that one stock Z would dyno 40 more WHP over another. That would be like 2 different cars.
Old Mar 21, 2006 | 09:30 AM
deviljon's Avatar
deviljon
the previous dyno result i had are being tossed. The car will be redynoed over and over again, each time with a different part of the catback system, and then finally with the complete system on. the car will never come off the dyno, therefor the readings will be more accurate since it will be done around the same temperature and other variables will be consistent.
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
