Help Nav Problem? Anyone Else Have This Prob?
MY04 NAV door will get stuck or stop in the middle of travel rendering no nav usage? its so erratic? ive had it in the dealer and warranty replaced 7 times. they just keep replacing the elec circuit that operates the door and or door itself? also a while back my dvd rom unit went out twice?
anyone else?
anyone else?
Mine is a piece of junk! I just got the phone call that my amp is here so they can take apart my dash for the 7th time and replace the brain that operates the nav door opening and closing....
ANYONE ELSE? IM HOPE'N IM NOT THE ONLY ONE HERE???
I had a problem with my 04.5 nav door opening/closing. It was making a grinding noise and not completely opening. Took it to the dealer and they replaced the entire door unit and the nav unit that reads the CD as I was getting a disc read error. Now, everything works better, is quieter and I've had no problems. I know the door unit was replaced because I had to reposition the LCD screen cuz it was a bit crooked after they worked on it. I could see that the mechanical pieces were different and the slider that door follows was different.
Wasn't there a TSB about this issue?
Originally Posted by yeperra
I must have a the only one on the planet that works just fine. I'm going to knock on wood, I mean plastic.
If it gets any worse I will have to remember to carry a crowbar with me just in case.Attachment 100021
