tire pressure - how do i decide
Old Mar 27, 2006 | 09:35 AM
StillAlive2029's Avatar
StillAlive2029
Default tire pressure - how do i decide
I have no idea what pressure my new wheels and tires should be at...should i run them at the stock reccommended pressure? or should i find out somewhere what it should be? thanks
Old Mar 27, 2006 | 09:44 AM
Vamos_Rafael's Avatar
Vamos_Rafael
what do u use ur car for?
street driving keep it stock (35psi?)
drag = less (more tire on the ground)
drft/autox = more (less tire roll when sliding)
(im running 38psi on the street)
Old Mar 27, 2006 | 07:00 PM
StillAlive2029
thanks a lot
Old Mar 27, 2006 | 07:23 PM
ClaytonC01's Avatar
ClaytonC01
or you could look on your tires to see what the recommended pressure is... now theres an idea
Old Mar 27, 2006 | 07:35 PM
StillAlive2029
i think i looked at one point and didnt notice it on there...is it always on there?
Old Mar 27, 2006 | 10:30 PM
Maximum recommended tire pressure is written on the side of the tire. The only situation that I can think of where you might exceed maximum recommended tire pressure is autocross.
Old Mar 27, 2006 | 10:42 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
not to hijack your thread or anything.. but our factory recommended tire pressure is 35psi when tires are cool, correct? when i fill it up to 35, it goes up to 38/39 after i drive it around a while and i feel as if i may not be getting as much traction as i should be. so should i only have it at 32 so when it warms up it's at the recommended tire pressure? again sorry to hijack your thread, this just popped up in my head
Old Mar 27, 2006 | 10:46 PM
Correct. The recommended tire pressure is 35 PSI cold. Cold is in the morning before the car have been driven.
Old Mar 28, 2006 | 07:16 AM
StillAlive2029
i cant seem to find the tread again...i know its here somewhere...but how do you get rid of the basically error screen on the psi info thing that i want my mph to show up on...i have hitting the reset button or whatever to get my mph to show up everytime i start my car...please dont tell me to search...already did and i know its there, but i cant find it
Old Mar 28, 2006 | 04:00 PM
StillAlive2029
bump
Old Mar 28, 2006 | 04:39 PM
MustGoFastR's Avatar
MustGoFastR
Why are you getting an error screen? The only time it should show up like that is if the TPS senses that you pressures are too low (like below 27-28PSI); fill them up to recopmmended pressure and it should automatically go away with a little driving.
Regardless of what tires you are running, you should go with the recommeded PSI for the CAR (35 PSI cold) for street use, unless, like noted above you are racing and have different requirements.
Old Mar 28, 2006 | 10:39 PM
3hree5ive0ero
Retired Admin
on the computer screen.. when viewing the tire pressures.. which one is left and which is right? is the top number left or right?
Old Mar 29, 2006 | 06:26 AM
MustGoFastR
Not sure. I don;t think there is a standard for that. You just have to let some air out of one tire and drive a little ways, then you'll be able to tell.
Old Mar 29, 2006 | 01:52 PM
StillAlive2029
its cecause i do not have the stock tires and wheels on...the tps is in the stock wheel or somehing
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
