does your 350z "burp"?
Old Mar 31, 2006 | 09:02 AM
babadudu's Avatar
babadudu
Default does your 350z "burp"?
HI all,
I i own a 2003 automatic touring 350z. I have had this problem for quite some time now...
sometimes, I feel a short burp while constant accelerating , it feels like when you suddenly take your foot off the gas pedal , then step on it again...
if anyone could help it would be great...
because when I told the service about this problem, they said they cannot find the problems.
Old Mar 31, 2006 | 09:04 AM
97supratt's Avatar
97supratt
Originally Posted by babadudu
HI all,
Then stop giving it too much soda!
Old Mar 31, 2006 | 12:07 PM
XV8DRVR's Avatar
XV8DRVR
I have an 04 and it does the same thing...can't figure it out.
Old Mar 31, 2006 | 02:30 PM
97supratt's Avatar
97supratt
Could be a misfire.
Old Mar 31, 2006 | 02:37 PM
cracka350z's Avatar
cracka350z
mine mini-farts while idling
Old Mar 31, 2006 | 02:39 PM
XV8DRVR's Avatar
XV8DRVR
Originally Posted by 97supratt
Could be a misfire.
Wouldn't that throw a CEL though?
Old Mar 31, 2006 | 03:19 PM
Cannysage's Avatar
Cannysage
Mine only burps after a nice meal.. such as mustangs, acuras and hondas
Old Mar 31, 2006 | 04:55 PM
6swhite350z's Avatar
6swhite350z
burp.. as in backfire?
Old Apr 1, 2006 | 05:06 AM
up2nogood's Avatar
up2nogood
mine too
Old Apr 1, 2006 | 05:29 AM
XV8DRVR's Avatar
XV8DRVR
It's not a backfire, it's like when accelerating it hesitates for a second, like the original poster said, it feels like you took your foot off the gas for a quick second then began accelerating again.
Old Apr 1, 2006 | 06:58 AM
Cozmo's Avatar
Cozmo
i think you're feeling it shift lol
Old Apr 1, 2006 | 08:18 AM
saberphx's Avatar
saberphx
bahahaha +1
Old Apr 1, 2006 | 08:37 AM
Aggro_Al's Avatar
Aggro_Al
If it happens in 1st, 2nd or the low end of 3rd gear, it's torque multiplication. It feels like you let off the gas but you didn't. Torque is actually multiplying at an accelerated rate until the torque converter couples. The tranny is creating more torque than the engine is outputting. After it couples the transmission can no longer torque multiply and it feels like you slowed down slightly. If it happens in the high end of 3rd gear, 4th or 5th, it's the mechanical clutch locking the transmission. The tranny can no longer torque multiply or adjust torque when it's locked. Instead of being allowed to vary the gear ratio, the 5AT is locked into a fixed gear like the 6MT by a mechanical clutch.
Old Apr 1, 2006 | 08:40 AM
XV8DRVR's Avatar
XV8DRVR
Uh, I don't have an automatic and it happens at different points in the powerband and different gears.
Old Apr 1, 2006 | 09:02 AM
Aggro_Al's Avatar
Aggro_Al
In the 6MT there are several things that can cause it to pulse, things like the clutch disengaging/re-engaging can cause it "burp". Since, you manually add or remove the engine from the rest of the drivetrain the load change can cause it to "burp". Also, in the RPM range you are driving in, a slight change in the throttle may cause a pulse. The 6MT uses a weighted flywheel to help smooth out those pulses. The heavier the flywheel the less significant those pulses are but it is harder to accelerate. A lighter the flywheel can accelerate faster but your pulse swings will be more significant and more often.
If you're 6MT is experiencing lots of "burps" under normal conditions and you haven't modified it you need to take it in to get checked out.
Old Apr 1, 2006 | 09:16 AM
Fletch69z's Avatar
Fletch69z
Probably back pressure. Mine used to do it when I had the stock exhaust which is pretty free flowing, but after changing to straight through exhaust I get back pressure pops pretty frequently.
Old Apr 1, 2006 | 09:33 AM
roast's Avatar
roast
If it happens regularly then I guess that rules out bad gas. Probably not a problem with plugs or wires either? Have you cleaned out the air filter box lately? It sounds more like a fuel delivery or timing problem. It could be anything. Take it to the dealer if you can't get to the bottom of it.
Old Apr 1, 2006 | 10:58 AM
XV8DRVR's Avatar
XV8DRVR
Hmmm...all good points. I'm running a JWT intake, perhaps it's time to clean it. The clutch/flywheel are stock but I think it's almost time to replace the clutch (50k miles) so perhaps that has something to do with it as well...
Old Apr 1, 2006 | 12:13 PM
roast's Avatar
roast
Definitely. Clean it and see what happens. I change filters and clean my stock airbox regularly.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
