Urgent!! Dyno Test Tomorrow - Any Suggestions?
Old Apr 13, 2006 | 09:05 PM
username's Avatar
username
Default Urgent!! Dyno Test Tomorrow - Any Suggestions?
Sorry for the last minute question, but I am having my 03.5 6mt G35 sedan dyno tested tomorrow morning. Does anyone have any suggestion to ensure that I get the correct info from them?
Example: What gearing? Do they do the A/F ratios with a standard dyno? Any suggestions?
Thanks.
Old Apr 13, 2006 | 09:21 PM
You mean get the correct information to them.
Test should be done in the gear with a 1:1 ratio.
Air:fuel ratio is standard with a dyno test.
Old Apr 13, 2006 | 09:33 PM
username's Avatar
username
Yeah, do I tell them 5th gear or 4th gear? Should they blow a fan on the engine while doing this? Sorry for the lame questions, but this is the first time that I have ever had a car dyno'd. Thanks.
Old Apr 13, 2006 | 10:04 PM
Cannysage's Avatar
Cannysage
they'll know what to do.. shops usually do at 4th (dunno why). is your car completely stock?
Old Apr 13, 2006 | 10:06 PM
username's Avatar
username
No, I have the Stillen TD catback exhaust and 350z intake tube. I am have the Stillen SC going on Monday. But I want to get a before and after.
Old Apr 13, 2006 | 11:02 PM
100122923's Avatar
100122923
I remember the first time I had my car dynoed, it was done in 4th as well. I ask the tech why and he said it's better for the drive train. He then showed me a run in 5th and the results were alsmost identical (+/- 1hp)
Old Apr 14, 2006 | 09:56 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
^^^ Same here... Did my baseline in 3rd than my pulls after mods where 4th/3rd/4th. Only a +/-1whp. The reason I was told not to do a 5th or 6th gear pull cause of heatsoak. Since the pulls are longer in higher gears the warmer/hotter the engine gets. Heat = less power. Just my $0.02
Old Apr 14, 2006 | 09:59 AM
Alberto's Avatar
Alberto
Cranky FI Owner
5th gear, turn off VDC, and ask for BOTH non corrected (actual) and SAE corrected #'s....good luck
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
