Help Needed - Overheating Problems
Old Jun 4, 2006 | 05:59 PM
roast's Avatar
roast
tekk.... if anything, you might check your radiator fans to make sure they are working. I don't think your car should have overheated unless there is a problem somewhere. It's just not a good idea to leave a car idling like that for no good reason.
With the engine off, pop the hood and locate the radiator fans if you don't already know where they are. They are behind the radiator on the engine side.
Then start the car and make sure the air conditioner is on. Then go check the fans, they should be turning.
Are they?
If they are, that means the fans are at least working, and it isn't something simple like disconnected wires. However there is also a temp sensor that determines when to turn the fans on and off. The sensor could be bad causing the fans not to turn on/off once a certain temp is reached.
If your car is still under warranty, you might take it to a dealership and tell them that you left the car idling for a little while and it overheated(shouldn't have happened), and you want them to check it out. It doesn't sound like it overheated enough to cause damage to your engine but you never know. I don't think aluminum engines take too kindly to overheating.
Old Jun 5, 2006 | 03:22 AM
tekk's Avatar
tekk
thanks.. the dealer is less knowledgable than i am (not a joke) so i try to learn to fix my car myself if possible.
i know where the fans are and have been keeping an eye on them. where i am (caribbean) its summer all year round. sometimes even if the ac isnt on, the fans spin up and then shut off. with the ac on the fans will come on, so they definitely work.
i did a good bit of extra driving yesterday, fast and slow. the temp needle stayed normal. so far, so good. to be safe ill probably be adding coolant though.. and at the next oil change ill probably change the coolant
Old Jun 5, 2006 | 07:56 AM
350Zenophile's Avatar
350Zenophile
Just be sure to fill the coolant when the car is cool. If you put too much in it will just overflow through the tank and make a mess, but no harm will come to your engine.
I recommend finding a copy of the Factory Service Manual for your year vehicle before attempting this yourself. Here is the cooling system troubleshooting section from the 04 FSM:
File Type: pdf
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
