GTech Times for 350Z Automatic w/Mustang GT Comparison
Old Feb 15, 2003 | 11:44 AM
Intrepid's Avatar
Intrepid
Default GTech Times for 350Z Automatic w/Mustang GT Comparison
GTech Times for 350Z Automatic Touring
Conditions / Settings
Temperature: 27 deg
Input Weight: 3,400 Lbs.
Tires: Michelin Pilot Sport A/S OEM Size
== 0-60 Times ==
Traction Control On: 5.82
Traction Control Off: 5.62
(best of 5 runs)
I'm impressed with these numbers for an Auto. I didn't have enough time to do more runs and improve my launch. I will test again when it's a bit warmer and see if I can replicate and/or improve these times. I will also be taking my Z to the track this spring and I'll let you know the "official" times.
NOTES: With Traction Control Off, if you just mash the gas your tires will spin and you will get a lousy time. You need to quickly feather the gas until your tires grip and then floor it. This is tricky, but required for best times. When it's warmer, this may not be as difficult. Obviously, brake torquing is not required. With a pair of slicks, I'm certain the Auto could see at least 5.5.
Comparison - My Old 2000 Mustang GT Auto
== 0-60 Times ==
Temperature: 80 deg.
Stock (TC Off): 6.34
*Modified (TC Off): 5.74
*Modifications:
+ 3.73 Rear Gears
+ Steeda Pulleys
+ Bassani X-Pipe w/high flow Cats
+ Modified Stock Induction w/K&N Filter
+ Performance ECU
Old Feb 15, 2003 | 12:28 PM
jasonintoronto's Avatar
jasonintoronto
wow dude, that's great with an auto and all season tires. congrats.
Old Feb 15, 2003 | 01:31 PM
Boomer's Avatar
Boomer
Default Re: GTech Times for 350Z Automatic w/Mustang GT Comparison
Temperature: 27 deg
== 0-60 Times ==
(best of 5 runs)
== 0-60 Times ==
*Modifications:
+ 3.73 Rear Gears
+ Steeda Pulleys
+ Performance ECU
Those are very good times for an auto. Makes me feel even better about choosing the 5AT. Thanks for your data.
Old Feb 15, 2003 | 05:46 PM
JonsilvZ's Avatar
JonsilvZ
Impressive times-Auto or manual mode? rpm shift?
Old Feb 15, 2003 | 06:06 PM
S8ER95Z's Avatar
S8ER95Z
Bagh... G-Techs just give you a better guess at what you can get.. I personally don't think they are even close to acurate. Goto a Track... and use the 0-60 calculator with your timeslip info.
Otherwise the good ol G-tech got me a 0-60 best of 6.2
1/4: 13.5 @ 113mph
HP: 318
They seem to work well to show you how much a new mod helped out..but not for real world times.
Old Feb 15, 2003 | 07:02 PM
JonsilvZ's Avatar
JonsilvZ
1/4: 13.5 @ 113mph
HP: 318
When your comparing times from the G-tech I guess the Z times are quicker then your 6.2
Old Feb 15, 2003 | 08:13 PM
Intrepid's Avatar
Intrepid
Auto Mode. Looking forward to a track time to compare. Will Let you know. One thing is certain - my stock Z is faster than my fairly heavily modded 2000 Mustang GT V8.
S8ER95Z,
What weight did you input into your GTech? Was you GTech showing 0g right before your run? This is very important.
Old Feb 15, 2003 | 08:55 PM
ares's Avatar
ares
Veteran
not bad, but yeah Gtech is a bit optomistic, but you can certainly compare times between them, as you have. higher temps will certainly help the Z, eventually the heat will be counter productive, but you arent really in the operating temps of the tires, so all the hp in the world wont help if you cant connect it to the ground.
Old Feb 15, 2003 | 10:20 PM
socalsoda's Avatar
socalsoda
What the hell if Gtech?
Old Feb 15, 2003 | 11:26 PM
Intrepid's Avatar
Intrepid
Please see here: https://my350z.com/forum/showthread....threadid=19446
Old Feb 16, 2003 | 10:36 AM
Intrepid's Avatar
Intrepid
Important GTech Rules for Accurate Results:
1. Input your correct car weight, including passengers.
2. Make sure your GTech is pointing straight ahead.
3. Most Important: Make sure your Gtech reads 0g before you launch. If it doesn't, carefully adjust it's incline until it does read 0. This ensures that the GTech is perfectly level. This is critical.
Old Feb 16, 2003 | 10:45 AM
socalsoda's Avatar
socalsoda
Cool stuff.... Thanks
Old Feb 16, 2003 | 02:23 PM
S8ER95Z's Avatar
S8ER95Z
Im aware on how its suppose to work
LOL
I input my 140 lbs on top of the curb weight (3460)... The G-tech was off when I ran it at the track as well. Not but a ton, however 2 or 3 tenths is still off pretty bad. The G-tech just doesn't cut it for sticking your numbers up to say a Diablo VT 0-60 times and comparing.. its not accurate enough. It may give you a decent guess.. but I think you are selling yourself short with what it gave you. I would suspect your 0-60 to be quicker than that. Thankfully I never paid for the G-tech..or I would be kinda pissed I think.
Old Feb 16, 2003 | 02:25 PM
S8ER95Z's Avatar
S8ER95Z
Yeah.. well it doesn't help that I can go WOT at 50mph and still break the tires loose. However after many smooth track launches and smooth street launches I got to know the difference between a nice 0-60 and a good one.. but the G-tech doesn't seem to make sense sometimes.
Old Feb 16, 2003 | 03:23 PM
Intrepid's Avatar
Intrepid
I'm sure the Gtech results are off somewhat. Looking forward to testing at the track when it opens again next month.
JjL
East Canada
Jun 12, 2019 03:04 AM
davidm350
Oct 31, 2015 02:28 PM
hardkicks
Sep 20, 2015 12:28 PM
RyansZ33
Sep 15, 2015 05:54 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
