easily chirp tires on 2nd gear on Z?
Old Feb 18, 2003 | 03:48 AM
MannishBoy's Avatar
MannishBoy
If you cut VDC off, it does it pretty easily.
Old Feb 18, 2003 | 04:58 AM
2003z's Avatar
2003z
When its cold with these pos tires, my car spins to redline in 2nd.
Old Feb 18, 2003 | 06:35 AM
ares's Avatar
ares
Veteran
even in warm temps I can easily make the back end step out, chirping is left to 3rd.
Old Feb 18, 2003 | 08:46 AM
kohlersc's Avatar
kohlersc
Spinning tires in second is very doable. I can chirp in 3rd well too. Spinning in 3rd is possible when cold/wet.
Old Feb 18, 2003 | 09:44 AM
Del350's Avatar
Del350
I rented an s2000 last time I was in vegas, if you beat it it will easily chirp going inot 2nd.
Old Feb 18, 2003 | 09:52 AM
ares's Avatar
ares
Veteran
you have to power shift to chirp third or spin 2nd. but you can chirp 2nd with straight power. in wet conditions you can be doing 10mph in 1st, step on it, and the tires will spin, dont even have to be in the power band.
but yeah, the Z has a bit more force behind everything, for example, the Z has 200ftlbs at 2000RPMs, while the S2000 has only like 156 ftlbs MAX. also the extra mass of the V6, with a heavier flywheel, ect. leads to a bit more UMPH when you power shift.
Old Feb 18, 2003 | 10:38 AM
Phi-1002-'s Avatar
Phi-1002-
On cold tires, foot off clutch, @ 4000 rpm in 2nd gear...
If I gun the throttle, the tires spin wildly. Lotsa' torque, not enough traction. Stook is completely different car.
Old Feb 18, 2003 | 11:36 AM
bobbyz's Avatar
bobbyz
In cold, If I am slowly cruising in second at 3000rpm and then floor it, the VDC kicks in, I see "slip" light up and feel it slide and correct. Doesnt have to be a power shift...or even a shift for that matter
Old Feb 18, 2003 | 02:57 PM
MannishBoy's Avatar
MannishBoy
IMO, you don't even have to powershift to get it to spin in 2nd. I shifted into 2nd a few minutes ago under 6000 rpm, and it still made the VDC kick in, and I didn't power shift (I assume you are meaning not letting off the gas at all when clutching).
IMO, though, this engine seems to hold its RPMs for a bit after you let off the gas. I don't know if it is a heavy flywheel, or just the fact I haven't daily driven a performance car with a MT in awhile and am forgetting how other cars I've driven in the past have performed.
Old Feb 18, 2003 | 04:10 PM
NismoEagleRock's Avatar
NismoEagleRock
funny this was brought up.... i haven't really punched my car until this past weekend... i decided to wait until i hit at least 2,000 miles before i tested to see how much potential the z had... and so, with confidence i can say that the z does chirp from 1st to 2nd easily (i even had vdc on)... i took it up to 6000 rpms before i shifted, and i felt the rear end come out... clearly, it was one of the most exhilirating experiences ever!
Old Feb 18, 2003 | 04:11 PM
NismoEagleRock
oh yeah, i didn't powershift either...
Old Feb 18, 2003 | 04:37 PM
MannishBoy's Avatar
MannishBoy
Originally posted by nismoz
heavy fly wheel? anyone have light flywheeL?
Nismo is going to release a lighter one. It just seems to take a bit longer than some cars I've driven for the RPMs to drop off when you are at high RPMs already. I may be totally off base, as I've said.
Old Feb 18, 2003 | 04:55 PM
JonsilvZ's Avatar
JonsilvZ
My tires were fully warmed. I was in manual mode. Shifted to 2nd when the rpm went over 5000. I felt the back end going to the side! Kind of scared me. Ahh the low to mid end torque..is impressive for a 3.5 v6.
Old Feb 18, 2003 | 06:16 PM
ares's Avatar
ares
Veteran
hmmm better get my car to a dyno, cause mine dont do this, 3000RPMs in 2nd on dry pavement and the wheels will spin? not in my Z.
Old Feb 19, 2003 | 01:44 AM
integrate's Avatar
integrate
6 speed here.
Warm (or cold), I can chirp into 2nd very easily.
Old Feb 19, 2003 | 06:07 AM
Zaphod 350z's Avatar
Zaphod 350z
I can barely hold third in this 30 degree weather. Even if I'm in the gear, if I floor it bye bye traction.
