Air Pressure in the ECU
Old Jul 6, 2006 | 01:12 PM
  #41
nothingremains's Avatar
nothingremains
i did check them and went by the book, the book said 35, so i kept it there, when i took it to goodyear cuz they were bald they said ford changed the tires and that they weren't the regular stock tires that came on the escapes and they never told me and that is why they wore out so quickly. So please tell me how that is my fault?
Old Jul 6, 2006 | 01:41 PM
  #42
VO...'s Avatar
VO...
Administrator
Air Pressure for 350Z:
1. Go by what car sticker suggest. Sticker will either be in door jam or behind center console door. Most people run 35 psi all the way around.
2. Tire pressure rating the Nissan recommends should be used on any brand or size of tire.
3. Tires should be inflated/adjusted when cold. The temperature will rise as you drive. Warm air expands and builds pressure. This is why the psi reading will increase a few pounds while you are driving.
BTW, there is no pressure in the ECU
Old Jul 6, 2006 | 03:03 PM
  #43
240Zplus110's Avatar
240Zplus110
Just to warn you... the tires selected for the Z are a good combination of handling and grip... at the expense of wear. Being super vigilant with the tire pressure won't measureably increase the life of your tires.
Old Jul 6, 2006 | 04:17 PM
  #44
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
My mistake, I misread the post above the one that I quoted. But either way, you're responsible for checking your tire pressure often. Also, you should've noticed the uneven wear on the tires before they were bald.
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
