StopTech BBK saved me this weekend...
Old Jul 17, 2006 | 10:48 AM
VO...'s Avatar
VO...
Administrator
Default StopTech BBK saved me this weekend...
Thought I's share a story with you guys. Some of you guys have seen pictures of my car, but for those that haven't I have 4-pot 14 inch drilled front brakes on the Z. I rarely take it out because I usually reserve it for show. This weekend I decided to take her out to a family BBQ. The route to my father's home is via Beltway 8. The Beltway is a super highway that circles the outter most part of Houston. You must pay to ride the Beltway, but it's worth it. The majority of the time there's light traffic and it offers a smooth bumpless ride.
Being early in the morning with light traffic I decided to open her up alittle. I got her up to 100mph and cruised smoothly. That's when it happened. I came around a blind corner. The Z is lowered, so it's difficult to see over concrete barriers on the highway also. At the other end of the corner, all traffic stopped to a stand still due to lane closures. Luckily I didn't panic. Instead, natural reaction was to immediately check my speed, down shift, & hit the brakes. ABS kicked in after a second, as I could feel the pulses in the brake pedal. I wasn't sure if the car was gonna stop or not. All I could think about was, "are the brakes going to heat up and give?" Then the realization that I had a BBK kicked in. The 4-pot StopTechs performed beautifully. The Z came to a hault extremely fast with no skidding or brake fatigue.
-VO, one satisfied customer-
Old Jul 17, 2006 | 10:52 AM
davidf's Avatar
davidf
Intrested in pics. of your car. Thanks.
Old Jul 17, 2006 | 10:57 AM
diwun67's Avatar
diwun67
Did you get dizzy? Sometimes braking hard like that makes me dizzy for some reason lolz
Old Jul 17, 2006 | 10:58 AM
VO...'s Avatar
VO...
Administrator
My forehead had a "Z" imprint from the steering wheel.
Old Jul 17, 2006 | 11:00 AM
VO...'s Avatar
VO...
Administrator
Old Jul 17, 2006 | 11:08 AM
plumpzz's Avatar
plumpzz
i get really dizzy if i slam the brakes then hit the gas right after. it really eff's me up. i like it.
Old Jul 17, 2006 | 11:14 AM
davidf's Avatar
davidf
Very nice.
Old Jul 17, 2006 | 11:18 AM
VN_350z's Avatar
VN_350z
I smell B.S.
If you had to stop the car so fast:
1)Why you even have time to check your speed (take at least 1 second)
2)Down shift (2 second at least)
Shouldn't you slam on the brake right away? You know what distance you would travel in 3 seconds at 100 mph?
"No skidding": it's not the BBK that causes skidding. It's ur tires and ABS.
"Brake fatigue": you were not even repeatedly using the brake on ur car. How did the brake even get fatique?
Old Jul 17, 2006 | 11:22 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by VN_350z
I smell B.S.
It's about the best I can recap everything. The story is not meant to be taken verbatim and disected for detailed accuracy.
Old Jul 17, 2006 | 11:25 AM
diwun67's Avatar
diwun67
He was probably already braking when he checked his speed and downshifted....that's what I would've done.
Old Jul 17, 2006 | 11:29 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
1. Beltway 8 is not a super highway (as in Europe). There is a speed limit there.
2. After spending $2K +, you should have that "happy feeling".
3. Consider yourself lucky that you didn't hurt anyone else for going 100mph+ on that 2 lanes beltway.
Old Jul 17, 2006 | 11:31 AM
VO...'s Avatar
VO...
Administrator
+1. You could say it was a natural reflex to hit the brakes and check speed to see what gear I could downshift into safely. I went into 4th but probably could've hit 3rd by the time I reacted with the shifter, mainly because the car had more than likely dropped below 80mph already. Either way, 4th or 3rd is still better than 6th.
Old Jul 17, 2006 | 11:33 AM
VO...'s Avatar
VO...
Administrator
+1 on the European highways. The belt way is 4 lanes each way.
Old Jul 17, 2006 | 11:41 AM
CFaddict350z's Avatar
CFaddict350z
I dont understand why some people on here doubt a story?? wtf? that pisses me off about this forum,, dude, his car has some sick brakes, the car stopped hardcore and nobody was hurt,, who gives a **** on the exact timing of all the reactions,,, jesus just appreciate the bump for the sick *** brakes!
Old Jul 17, 2006 | 11:52 AM
1nate7's Avatar
1nate7
I don't doubt his story, but reality is the stock brakes perform just as well for 1 hard panic stop. The advantage of the BBK is heat dissipation for repeated hard stops from high speed. I am glad the brakes performed as advertised and no damage was done.
Old Jul 17, 2006 | 11:56 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
OEM brake would give out pretty much the same result in his situation. I guess he is just so excited about. I would be the same if i spend 2K+ on the damn BBK. lolz
Old Jul 17, 2006 | 12:07 PM
Miko's Avatar
Miko
Is the advantage of a BBK that there is less "break fatigue"? Like using OEM constantly such as at a track, you'll end up feeling loss in braking power...
Nonetheless, the BBK you have is bad *** & sweet looking!! That is what should've came instead of the Brembo's!
Old Jul 17, 2006 | 12:12 PM
Built2shredZ's Avatar
Built2shredZ
Thats the kit I want to get for my Z but at all four corners (mainly for looks since I don't race my roadster)... Just trying to part with the $4k thats hard
Probably do it sometime in Sept. as my Z is pretty much just sitting in the garage right now because its to damn hot to drive it.. was 118 here yesterday
Old Jul 17, 2006 | 12:15 PM
VO...'s Avatar
VO...
Administrator
Thanks for the comments guys. Bubble hit the nail on the head when he described it as being an excited feeling I wanted to share. The OEM brakes would have been enough to stop the vehicle in one emergency application. This is true. I'd have to admit though, it feels good knowing that the product worked well under pressure considering I did the install without making any vital mistakes.
